J/D jetting kit??
4 replies to this topic
  • flintlock28
Posted April 04, 2007 - 10:06 AM
Running the j/d jetting kit in my 04' 450f. I'm using the blue needle right now for between 47 and 60 degree weather. At what temperature should I switch to the red needle?? I would guess about 70 degrees or higher, but I'm not sure??? Let me know, thanx.:bonk:
Posted April 04, 2007 - 10:10 AM
In their kit for the 250F, the blue and red needles were for different altitudes, not temperature ranges. What do the instructions that came with it say? They're normally pretty informative.
  • 642MX
Posted April 04, 2007 - 11:05 AM
^^^^ The instructions reference altitude and temperature ranges for the 250/426/450 applications.
I use the red needle year round. My bike sputters a little of the bottom end with the blue needle. Same with my wifes 250F, we use the red needle all the time also.
  • Ga450owner
Posted April 04, 2007 - 11:36 AM
At my altitude - 900-1800ft I swap to the red needle at 65 and above.
  • flintlock28
Posted April 04, 2007 - 01:35 PM
The instructions were somewhat ambiguous, since they listed the red needle for High humidity and/or high temperature. So that's why I'm guessing the cutoff may be around 70 or so;not sure. I usually ride from Sea-level, to about 1800 feet above.
