Calling All Aussies
8 replies to this topic
  • Thermos O flask
Posted April 04, 2007 - 03:06 AM
Can someone tell me if BALLARDS valve shim's are as good as YAMAHA shim's?
Or are they made of the same metal as the genuine shim's and not cheap CHINA
CRAP?
  • gregwr450f
Posted April 04, 2007 - 05:40 PM
I have no idea, but I can probably hook you up with some some genuine ones for way below RRP if that helps.
  • fitzy
Posted April 05, 2007 - 02:19 AM
just go gen. Then you know what you have
  • Aus_WR450FS
Posted April 05, 2007 - 08:07 PM
Don't mess around and just get genuine Honda ones. The CRF450 has the same size shims as the WR450.ie 9.48mm They are about $4.50 aud each and the sizes come in smaller increments (0.025mm not 0.05mm) allowing you get get closer to the tolerances you want.:bonk:
  • 450high
Posted April 06, 2007 - 02:51 AM
why not ring ballards and ask.All the gear seems top notch.
  • Thermos O flask
Posted April 06, 2007 - 04:16 AM
Thanks guys ,I like the HONDA shims idea:thumbsup: I went adjusting today..what a mission that was,when i measured the tolerances and got the shim size,worked out what shim to use and refitted everything.Rechecked the gap and no gap!! :bonk: I had to fit a new unused smaller shim than the one that was fitted.Remeasure the gap ,work out new shim size required.Then refit,at least it all measured out ok then.I think someone must have shaved the shims or can they wear?
I'll measure them at work .It would have been handy if i could have reused them.
  • Thermos O flask
Posted April 07, 2007 - 03:48 AM
I went down to get shims today and honda dont stock them? so i ordered a handfull at $4.50,went over to bike biz yamaha and they ony sell hotcams shims at $8 a pop,genuine yamaha are $13 each.Go the honda ones,thanks again for that one.
  • bens25au
Posted April 07, 2007 - 03:58 AM
I bought a Hotcams shim kit off ebay from the states which was pretty well priced. You get three 9.48mm OD shims in each size from 1.20mm to 3.50 in .05mm increments. I think its 120 shims for just under $115 delivered to your door.:bonk:
(there abouts)
  • Thermos O flask
Posted April 09, 2007 - 04:00 AM
yeah I think i should have done that,by the time i got a few different shims i'd have spent the much anyway!:thumbsup:
