For those who use a hydraulic brake light switch
11 replies to this topic
  • markturbo
Posted April 03, 2007 - 03:28 PM
I just installed a K&S switch but it seems a little slow to come when I step on the brake. I'm pretty sure I didn't lose any brake fluid during the install, but I ran out of daylight so I guess I can try and bleed the brake tomorrow.
Just wondering if this is normal for this switch, or if it should activate the light at the slightest touch of the brake...which I think it should?
Thanks
  • SXP
Posted April 03, 2007 - 03:36 PM
Thanks
Have you tried riding the bike and stopping with the rear brake only? Does it take more effort/travel of the brake pedal to stop than before you put the switch in? If so, you will have to bleed the line as air was probably introduced when you took the banjo bolt out. Once done, the switch should activate sooner as soon as sufficient pressure builds up.
  • markturbo
Posted April 03, 2007 - 04:16 PM
I haven't rode the bike again yet, although it did feel a little soft pushing on the brake. It probably does have air in the system from taking the banjo bolt off. I'll bleed it tomorrow and update.
Thanks
  • specialk6r
Posted April 03, 2007 - 05:50 PM
Yup, bleed em'. One good sized bubble (say, half the width of the line) is enough to make the brake almost useless.
  • Birdy426
Posted April 03, 2007 - 10:28 PM
I have the same switch. It comes on with very little pedal travel. Bleed that bad boy!
  • markturbo
Posted April 04, 2007 - 06:04 PM
What a pain to bleed it! I eventually ended up unbolting the caliper and zip tying it up on the upper sub frame to get all the air out of it...but it worked, seems to be working better now.
Next project, installing a Bajadesigns keyed ignition I picked up today.:bonk:
  • MountainMax
Posted April 05, 2007 - 09:23 AM
forsure you got some air in there, a little bleeding will make it perfect 4sure
  • Super_Dave_344
Posted April 12, 2007 - 06:40 PM
i just bought the same switch for my 04 WR450 & im installing it along with my steel front line this weekend.Cant wait to get this SM finished & go for a ride.
  • Jwar1r1t3
Posted April 13, 2007 - 03:13 AM
where did you guys get the switch and what is it called exactly? I would like to install a brake light switch on my 06 wr 450.
  • markturbo
Posted April 13, 2007 - 03:44 AM
I bought mine from here
http://www.gnarlypar...roducts_id=9004
That site is in Canadian dollars, they do have a US site as well.
  • MountainMax
Posted April 13, 2007 - 07:31 AM
I bought mine Here https://www.bajadesi...2.aspx?content=
  • AnimalDan
Posted April 13, 2007 - 12:43 PM
Or the Thumpertalk store has them for $2 less. Look under K&S hydraulic brake switch
