stock chain
15 replies to this topic
  • wrider
Posted April 02, 2007 - 01:56 PM
I picked up my new '05 wr450, and am gearing it up for a trip next month. I have read where many people suggest replacing the chain with an o-ring type before it wears into the sporckets.
looking at the chain it says DID VM 520, and looks like an O-Ring chain. can anyone confirm this?
thanks
  • trailordune
Posted April 02, 2007 - 03:43 PM
Yes, it is an o ring chain and a good one too.
  • SJMC_DON
Posted April 02, 2007 - 03:46 PM
Look close though and you will probably find that it does not yet have a master link, they tend to have one link with some pressed in pins that will have to be repalced with a master link should you need to remove it or it breaks... make sure to get a trail side chain breaker and DID Master Link before you venture too far off the beaten path:ride:
  • Jwar1r1t3
Posted April 02, 2007 - 04:26 PM
Yeah I noticed that on my 06 when I got it, and I've never seen anything like that before. My bikes always had master links that could be serviced w/ just a screw driver. Why does DID make it so complicated?:bonk:
Plus, I can't for the life of me, figure out which one it is!!!:naughty:
  • SJMC_DON
Posted April 02, 2007 - 05:31 PM
It's usually pretty obvious by the pin heads, on my 07' I can definitely tell which one it is...
I think Yamaha orders them for production made up that way, it's cheaper and they probably install them during a process that allows them to put them on in one piece...
  • trailordune
Posted April 02, 2007 - 07:23 PM
It's a riveted master link. You can also buy chains with this type of link. The snap on master link is the weakest part of a chain. If you need to remove the chain for replacement or service, just take off the swingarm and lube your bearings while you're in there. You'll be happy when it's done.
  • Aus_WR450FS
Posted April 05, 2007 - 11:29 PM
Sorry to be picky, but it is actually a premium X ring chain, which has better specs than an O ring. :bonk:
http://www.didchain.com/specs.htm
  • dazzabb
Posted April 06, 2007 - 01:43 AM
The stock chains are non-o ring which reduces friction alot.
Lift the rear wheel and spin it with a standard chain and it will come to rest far later than with an o or x-ring chain.
Having said that I replaced mine with a DID x-ring as the standard chain stretched too easliy for my liking.
  • SXP
Posted April 06, 2007 - 05:59 AM
Not here. O-ring chains are stock on the WR's.
  • johunter666
Posted April 06, 2007 - 08:45 PM
I'd say the stock o-ring chain and sprocket set up is awesome! I've got close to 1500 miles on mine with no visible sprocket wear and I haven't had to adjust for stretch since 3-400 miles.
  • jim-in-so-ore
Posted April 07, 2007 - 10:24 AM
My chain is the standard o-ring masterlinkless chain that came stock on my 03 450. I have over 5200 miles on my bike with the stock chain and I've only had to adjust the chain 3 times. The sprockets both look good too! Thats not a cheap chain as far as I'm concerned.:bonk:
Jim
  • tony1970
Posted April 07, 2007 - 04:32 PM
After 22 years of riding I have yet to see a properly installed clip type masterlink fail. If anyone here has had one fail on them please chime in.
  • trailordune
Posted April 07, 2007 - 09:37 PM
I've never had a problem either, but that doesn't mean it doesn't happen. I was pointing out the reason for the solid link chain and that is less failure, simple as that.
  • Gadsen
Posted April 08, 2007 - 08:21 AM
thanks
It is an Oring chain.
  • Gadsen
Posted April 08, 2007 - 08:25 AM
Yeah I noticed that on my 06 when I got it, and I've never seen anything like that before. My bikes always had master links that could be serviced w/ just a screw driver. Why does DID make it so complicated?:thumbsup:
Plus, I can't for the life of me, figure out which one it is!!!:worthy:
Its for competition. Its called a continous chain. The master link will have slightly different colored pins. I ground mine off and replaced it with a master link. A RK-520SO or RK-520XSO master link fits the DID VM520 chain perfectly also.
  • saqu
Posted April 18, 2007 - 12:44 AM
DID 520VM is X-ring chain, DID 520V is O-ring chain.
Riveted link is stronger than clip type:
http://www.didchain.com/install.htm
:thumbsup:
