Wire removal
2 replies to this topic
  • MaxPower
Posted April 02, 2007 - 12:37 AM
[COLOR="Green"]You know that funky little wire that runs from the clutch perch?
I want to remove it. do I cut them short and tie the together or tape them off seperatly? Thanks[/COLOR]
  • jim-in-so-ore
Posted April 02, 2007 - 05:40 AM
Loop them back together and solder them, then use shrink tubing. If you do this you can still use the electic start as it was intended but if you don't pull in the clutch the starter will move the bike while in gear.:bonk:
  • AnimalDan
Posted April 02, 2007 - 10:02 AM
Or just pull the little switch out of the clutch perch and tape it back on the wire harness. This will also work like Jim says.
