tire pressure questions
5 replies to this topic
  • dwnlowx
Posted April 01, 2007 - 11:51 PM
i have been trying to experment with my tire pressure all of my freinds run low pressure or at least some what soft to the touch and they all ways tell me to run lower pressure in my tires
i usually run about 15 psi and they are still rock hard
in the book it says to run about 12 -17 psi
what do you guys run on your tires whats the lowest psi you ride on and does it make your bike handle better or does or does it make it slower
any input helps
  • Dano426
Posted April 02, 2007 - 06:30 AM
12 psi in front and 14 psi in back. When I first got my bike(used) I was having some cornering issues. Someone recommened 12/14 to me to help with the front tire push and I have used that it since.
  • Mfinazzo
Posted April 02, 2007 - 08:18 AM
12psi for the front 10-12psi for the rear.
  • ruddell07
Posted April 02, 2007 - 08:39 AM
10-12 here too. I've run them at a lower PSI, but make sure you have heavy duty tubes...its a long walk home with a pinch flat.
Posted April 02, 2007 - 08:48 AM
There's a really good write up on this particular subject in the April MXA.
Basically, if it's too hard, the tire will bounce and skip around too much, and if it's too soft, you can actually loose traction from block rollover. On rougher, harder ground, you can cause "pinch flats" by running too little air, too. Read the article if you can find it, and experiment a little.
  • MDS55
Posted April 02, 2007 - 12:35 PM
13 Front 14 Rear
  • 5 replies
  • 0 replies
  • Hot  50 replies
  • Hot  36 replies
