Sheared subframe bolt
7 replies to this topic
  • hutcher
Posted April 01, 2007 - 06:15 PM
At the track today on my '04 450F cruising merrily across a double jump when I heard a loud POP. Didn't notice anything immediately, but when I pulled into the pits I discovered the subframe bolt just above the shock reservoir had sheared off. The head is completely gone and i can only see a bit of the bolt itself.
This happen to anyone else? What (besides taking it in to the dealer and having it drilled out) can I do?
  • BC3
Posted April 01, 2007 - 07:52 PM
If you can remove the other side and very carefully pull the tube that is held by the broken bolt straight off the bolt and to the side you should be able to grab the broken bolt with vise grips and remove it....
  • hutcher
Posted April 01, 2007 - 08:29 PM
I'll give it a shot - Thanks!
  • rmracer27
Posted April 02, 2007 - 03:11 AM
I broke mine, but it was after it took a hard hit on the back of the seat area. It was a pain to get out. I had to buy a new subframe and all but thats cause mine was bent.
  • kawirider
Posted April 02, 2007 - 04:21 AM
The head of a bolt on my subframe sheared off as well. It wasnt in the same location, it was the one bolt that holds up the muffler. So not only do I get to buy a new subframe, I get to buy a new exhaust system too. Yay!
  • Yamahafan
Posted April 02, 2007 - 06:39 AM
Craftsman (Sears) makes a "bolt-out" kit specifically designed to remove bolts with broken heads. You may find other brands as well.
http://www.epinions....t_Out_Set_52162
Posted April 02, 2007 - 08:33 AM
Something else you might want to try:
Apply a good, effective penetrating oil (WD-40 is pretty useless) Drill into the threaded end of the bolt (it should be exposed on the right side of the bike) with a 1/16 or 3/32 drill about 1/4" or so down into the bolt. If the drilling has not started to unscrew the bolt already, take the largest, sharpest drill you have that is still small enough to clear the threads in the frame, apply a little heat to the threaded eye in the sub frame if you have the ability to do so (even leaving it out in the sun for an hour is better than nothing) and then run the larger drill into the smaller hole you drilled earlier. Try to make the drill snag, and when it does, it will try to run the bolt out the opposite side.
  • kawirider
Posted April 02, 2007 - 10:15 AM
In my experiance PB Blaster works really really well. You have to soak it and give it a few hours to do its job but after that you can get it out no problem.
It even helped me get out the swingarm pivot axle (dunno if thats the right thing to call it) when it was bone dry and probably had not been moved in 2+ years.
  • 10 replies
  • Hot  50 replies
  • Hot  36 replies
  • Hot  30 replies
  • 3 replies
