What is the OD on a head pipe for an '02 WR426
6 replies to this topic
  • Toby_S
Posted March 31, 2007 - 03:05 PM
I actually have a WR250F, but I want to put the stock muffler on a powerbomb, and the OD of the powerbomb is bigger than the ID of the stock gasket (header to muffler). I think the Mufflers are the same for 250 and 426, so if the header is the same OD I can get a 426 gasket. OD measurement of gasket would be good if you have it.
Thanks,
Toby
  • TeamScream
Posted April 01, 2007 - 09:57 AM
Thanks,
Toby
Hey Toby, your lucky day.
I just happen to have 2 of those gaskets in my box brand new and my calipers out on the bench when I read this.
Yamaha part # 3VD-14613-01 (exhaust port to header gasket) 2002 YZ426F
O.D. 46.76 mm (1.837 in.)
I.D. 36.10 mm (1.421 in.)
  • Toby_S
Posted April 01, 2007 - 11:14 AM
I was actually looking for the ID that sleeve that goes between the header and muffler.
Thanks,
Toby
  • TeamScream
Posted April 01, 2007 - 11:45 AM
Thanks,
Toby
The ID of the sleeve you mention now would be the OD of the header pipe for a 426 which is right around 41 mm. :bonk:
That sleeve is soft so getting a proper measurement is near impossible.
I measured my stock 426 header and it is 41.33 mm at the header/mid pipe junction which is where that soft sleeve is used.
  • Toby_S
Posted April 01, 2007 - 01:07 PM
Thanks a lot! That's the same size as my powerbomb. The mufflers are actually different, though, so I need the OD of the Gasket or the ID of the muffler. I'm hoping that the muffler ID is right around 48mm. Do you have a muffler or gasket you can measure?
Thank,
Toby
  • TeamScream
Posted April 01, 2007 - 01:54 PM
Thank,
Toby
OK the OD of the gasket (sleeve) is between 48.30 and 48.55 mm, the sleeve as I mentioned is soft and you can bend it around really easily, so when they come new in the package they are not perfectly round, but I measured it in several places and came up with those measurements.
I am following this info closely because if you make this work I may get a powerbomb header to use with my set up, it seems like a good option.
I like the concept behind powerbomb.
So now I will ask you to do ME a favor,
I rarely come into the WR forum, I am mostly over on the SuperMoto forum, so if you make this work PLEASE send me a PM so I know it works and I have an option to use the powerbomb if I want to that way I wont have to come looking for this thread if it gets buried in the ether.
  • Toby_S
Posted April 01, 2007 - 02:46 PM
I'll keep you posted. It looks good. I checked on the parts fische, and the clamp band is the same for each bike, so the OD must be the same. Your measurements are in the ballpark too.
