07 WR450 TT AIS removal kit - tip
1 reply to this topic
  • Jammer
Posted March 31, 2007 - 11:47 AM
Just installed the TT AIS removal kit. The OE fitting at the front of the head, held on by 2 screws, is difficult to get at the 1 screw due to the rad pipe & hose getting in the way. I used an allen key with a "ball" end on it - so you can turn allen head screws with the wrench on an angle. Worked perfectly and I didn't need to drain the coolant, remove the hose, etc.
  • WR_Dave
Posted March 31, 2007 - 12:22 PM
Also when using the ball end allen wrench loosen the hard to get at bolt first and take it out before the easy one and then reverse the procedure for reassembly. WR Dave.
