Need help quick - 07 WR450, air jet won't b ootom out
2 replies to this topic
  • Jammer
Posted March 31, 2007 - 11:42 AM
I'm installing the Yamaha jets that came with the bike. Includes a 110 air jet. Dirt Bike article says it goes in mouth of carb, where there is no jet currently. There are 2 holes there - 1 is a needle air jet - I removed the stock jet & tried putting the supplied air jet in there but won't thread in (this is the hole on the left as you are looking at the carb mouth - new air jet is bigger in diameter). apparently the right hole is for this air jet, and it threads in but does not bottom out & stop.
So, is the 110 air jet necessary? What does it do? What happens if I don't use it?
all help appreciated & thanks in advance.
  • SXP
Posted March 31, 2007 - 06:34 PM
If this is the GYTR AIS kit then I believe there is a recall on the AIS kit because of the very problem you noted. Contact your Yamaha dealer for the correct size jet.
  • Jammer
Posted April 01, 2007 - 08:04 AM
I got the TT AIS kit & am using the needle/jets that came with the bike - in a separate bag. Anyway, got the jet installed, bike ssems to run fine. I have posted a bit more info over here:
http://www.thumperta...ad.php?t=489537
