Hour meters 07
14 replies to this topic
  • fitzy
Posted March 31, 2007 - 03:49 AM
Where is everybody mounting their hour meters on the 07's. Also Where is the best place to pick up the signal from?? Tried on top of the plug cap but no go. Pics please if you have them??
Thanks
  • simon@vic
Posted April 01, 2007 - 08:30 AM
you can some times get a signal off one of the wires going to the stick coil.
but your bike came with an odometer........just go by mi/km's for your maintenance. 300-500km for oil, 1000-1500km check the valves, linkages every 4 months, and everything else weekly!!!
  • msgbean
Posted April 01, 2007 - 10:45 AM
I mounted mine on the fuel tank mounting screw. Just made a little bracket out of a piece of tin. I just wrapped the wire around the top of the plug cap four times then wraped electrical tape around it to hold it in place.
  • Anthony CRF450
Posted April 01, 2007 - 05:05 PM
the pic looks good!!!
what type is it? i.e. brand
is it waterproof?
does the tacho work?
what would the service &Valve intervals be in hours? (not km's)
  • Gary Murray
Posted April 01, 2007 - 05:30 PM
I mounted it on the right handlebar just inside of the starter button and brake perch. I cut a 1/16" aluminum plate the size of the hour meter base and cut 4 holes in it to zip tie it to the bar. Then used the velcro to attach the gauge to the plate. It is easy to read and stays put very well.
  • fitzy
Posted April 02, 2007 - 03:49 AM
Couple of good ideas there fella's. Thanks
  • RJB
Posted June 08, 2007 - 03:13 AM
Thanks for the pics and tip here - I'll be mounting mine just like that.
  • SXP
Posted June 08, 2007 - 05:36 AM
Or just get a Vapor. You can transfer all the information from your current Odo to the Vapor (guesstimate the number of hours and enter it). Just as a guide, I'm at ~1100 miles/55 hours. And, you get the added functionality of knowing how hot your motor is running and a digital/bar tach.
  • RJB
Posted June 08, 2007 - 07:27 AM
SXP - do you have a pic of the Vapor install on your WR? I have the Endurance installed on my old YZ and found it pretty good.
  • SXP
Posted June 08, 2007 - 08:57 AM
I'll take some close-up pics tonight and post them.
  • face_plant
Posted June 08, 2007 - 01:19 PM
i just installed a vapor on my 05 very easy took 20 min for speedo 3 hours for thermo sensor(aluminum bolts in steel frame sucks) could not use the upper hose the sensor rubbed the tank so i used the lower and the wire was to short so i had to splice 8'' to make it work. the tach was the easiest after i found out what i was doing wrong..(HAVE TO WRAP THE COIL STEM not the wires to the coil..to mount it to the stock bracket turn it upside down and just use 1 bolt works fine....engine temp 135-200 degreese is this normal?
  • xrmarty
Posted June 09, 2007 - 11:53 PM
that's a great location for the meter if your running a stock tank. I was unable to put it there because I got the IMS 3.1 gal tank. Instead, I installed it on the frame.
  • PROWLER 58
Posted June 20, 2007 - 05:28 PM
I have a new 07 WR450, are you sure it has an odometer ? The mile markers have resets, which ive already managed to reset both. is that what your talking about ? ive looked in the manuel ,and no mention of odometer.
  • msgbean
Posted June 20, 2007 - 07:34 PM
It has two trip meters, A and B, which is the same as an odometer if you don't reset one of them.
  • PROWLER 58
Posted June 21, 2007 - 05:08 AM
Yes , thats what I thought. Ive accidently tripped both already.so I quess Ill never have a true odometer reading now.Just have to add about 40 miles to one of them for a general idea.
