yz426 rad cap
1 reply to this topic
  • mxgene
Posted March 30, 2007 - 04:06 PM
So I have been having an ever so small amount of coolant leak while riding.
I decided to put a Kawasaki 1.8 (vs 1.1) psi cap on to try to prevent boilover.
However, I found the root cause to be the o-ring on the tube that goes into the water pump was worn. When I put on the higher cap, the coolant came right out. So now I know where I have been losing coolant.
My question is this, will it hurt the bike to still use the 1.8 cap instead of using the stock 1.1?:bonk: :naughty:
BTW- I already have new o-rings for both metal pipes and ordered a new tube since mine had quite a bit of buildup on the inside.
Posted March 30, 2007 - 07:34 PM
http://www.thumperta...890#post4563890
