Moly grease, is it necessary????
10 replies to this topic
  • Ronin
Posted January 27, 2002 - 04:20 PM
I could not locate any moly grease today when I was working on my swingarm. So I packed it with red, high temp lithium. Is that okay??? I didnt know what else to do and I wanted to put the bike together ASAP. I am going to service the swingarm within 2 months anyways so I was hoping that the regular grease would work for the time being.
Thanks for your input,
Posted January 28, 2002 - 04:29 AM
Yeah, that's fine. The key is Resistance to Water. Many of us use the molly because of it's tendency to stay put even in High Temps. I lube my swing arm bearings and lower link every six months, although expereince with the Red Molly tells me I could go once a year with no problem. I ride hard every weekend.....
Bonzai :)
  • Ronin
Posted January 28, 2002 - 04:44 AM
thanks for the info, I kind of figured that grease is grease is grease. As long as you replace the grease within the service life of the grease a guy should be okay.
  • *mike68*
Posted January 28, 2002 - 12:20 PM
Use the Moly. The main reason for it's use it that it is a "high inpact" grease. A waterproof grease probably not giving the protection your linkage needs. Just something I have learned from other TT'ers here. Got mine right at VIP. If you can't find any for some strange reason, let me know and I will send pick some up for you and ship it.
Posted January 28, 2002 - 01:40 PM
You are still Alive! I knew the rumors were wrong.....
  • Guest_Guest_*
Posted January 29, 2002 - 03:37 AM
I found a white grease and a moly grease at Napa auto parts. :)
  • SoCalWR426
Posted January 29, 2002 - 06:05 AM
Sorry bud, but grease ain't grease. Without going into a bunch of detail. The moly itself acts as micro ball-bearings, great in high stress aplications as in a steel shaft turning in bushings (e.g swing arm), regular grease is more for ball-bearing aplications..If you can get to a boat/marine shop they should have h2o proof moly. h2o proof synth. moly would be the hot ticket..
Just my .02
  • JBM
Posted January 29, 2002 - 07:13 AM
I found Extreme Pressure Moly Graph at Autozone for about $3.00 and it has worked very well. It is highly water resistant.
  • *mike68*
Posted January 31, 2002 - 02:44 PM
Yup, Still alive. I've been watching you.......
  • SealClubber
Posted February 02, 2002 - 04:14 PM
Pro Honda makes a moly paste for about $9 for 3oz. It is 60% molybdenum disulfide (don't know what the other 40% is. It is part # H/C 2963866
  • SealClubber
Posted February 02, 2002 - 04:18 PM
Correction, it is part # 08734-0001. Your local honda dealer should stock it.
Dan :)
