Dented header fix
42 replies to this topic
  • KJ790
Posted March 24, 2009 - 02:01 PM
#41
will this work on a 2 stroke pipe as well?
Be careful with a two stroke pipe, the larger volume means a lot more expansion of the water as it freezes, which easily results in a split pipe. I have done this trick on many four stroke pipes, but I wouldn't recommend it on a two stroke pipe.
  • dziino4
Posted March 24, 2009 - 02:04 PM
#42
What would you recommend for a 2 stroke pipe then?
  • KJ790
Posted March 24, 2009 - 02:06 PM
#43
I've had good luck with pressurizing them and heating the dented areas with a torch. This can be dangerous if certain precautions are not taken, but you run a lower chance of damaging your pipe.
