overflow tube on carb pouring out gas help!
4 replies to this topic
  • otea487
Posted March 27, 2007 - 08:14 AM
I have pulled the float bowl off float needle out why does it keep leaking?debris?bad needle?
  • kskyles
Posted March 27, 2007 - 10:13 AM
try cleaning out the bowl again. any small debris in there might make the float stick.
then check your needle valve to make sure its seating properly. it may be a little worn and need replacement.
  • mkporn
Posted March 27, 2007 - 02:34 PM
make sure the float height is correct...
  • otea487
Posted March 27, 2007 - 10:12 PM
not exactly sure how to get proper float height any advice "MKPORN" would be greatly appreciated.
  • otea487
Posted March 27, 2007 - 10:16 PM
mornin "HOSS" lot of great info i see! 03/28/07 0015 hrs:ride:
