can I swap all components to a newer frame?
20 replies to this topic
  • YZ Purist
Posted March 25, 2007 - 06:42 PM
I was just curious if all my 2003 YZ250 parts would swap right over to the 05 and up aluminium frames.
  • wheelie man
Posted March 25, 2007 - 06:46 PM
I know the motor will fit, but you will have to ask RCannon or somebody else with godly knowledge to figure out about the suspension and other doodads.
  • YZ Purist
Posted March 25, 2007 - 06:52 PM
yeah, I was just curious. I honestly doubt I'll ever do it though. I just like the way the new frames look, kinda lame huh?
  • hart92
Posted March 25, 2007 - 07:01 PM
not lame i was thinking the same thing at one time and i think it was in dirtrider in one of there reader questions sections somebody was wanting to swap there parts over to an aluminum frame,they said it could be done but would be better off to sale it and buy an 05 or newer, nothing wrong with a 2003,those are also great bikes.
  • BRM
Posted March 26, 2007 - 02:54 AM
I would probably do the same, buy the later model then swap all my stuff onto it then sell the old one.
  • RCannon
Posted March 26, 2007 - 03:32 AM
We have talked about this before. A search should provide some god info.
As I remember it, the only part we were concerned with was the triple clamp...specifically the bottom one. Apparently the stops changed location when they went from steel to aluminum.
  • Markopolo400
Posted March 26, 2007 - 04:39 PM
Since you have a 2003 yz250, you'll need the newer 48mm forks, the 03s and older came with 46mm forks.
For the frame swap, besides the bottom triple clamp and forks, you also need a newer ignition with the built in grounds, since the grounds for the steel frame will not work with the aluminum frame.
  • busted bones
Posted May 27, 2008 - 09:44 PM
Sorry to revive the dead but since I was planning on doing this mod myself, is this all that has been found to be needed or is there anything new that needs to be switched?
  • mxdude629
Posted May 27, 2008 - 10:06 PM
just to add on. I think all you need ignitionwise is an 05 coil? mxa had somthing about that mod a while ago.
  • busted bones
Posted May 27, 2008 - 11:24 PM
Sorry for the ignorance on this but in my search I didnt find what I was looking for. Are the YZ250 and YZ125 frames interchangable? Or are the mounts different? Also are the YZF frames useable or is ther alot more involved in the swap than if I were just going to a newer YZ250 frame?
  • Vintage Not Pimpage
Posted May 28, 2008 - 01:45 AM
The YZ125, YZ250, YZ250F and YZ450F frames are all differenent and are not interchangable.
  • mxdude629
Posted May 28, 2008 - 07:55 AM
yeah i wouldnt bother trying to swap to a different bike frame. if anything go with newer yz 250 frame. And I just remembered you also have to trim down the gas tank rubber gromets as the aluminum frame is wider.
  • busted bones
Posted May 28, 2008 - 05:38 PM
Alright, thanks for the help guys. It will be a fun project to see how far I get with it and see if I can keep the green sticker.
  • YZ-2-Strokin
Posted May 28, 2008 - 06:31 PM
In all actuality theres really not a hole lot you would need to do for that frame swap.
You can get the harness on ebay for $20-$40 bucks.
Bottom triple clamp or complete from $40-$100 bucks
Everything else will fit except maybe the gas tank, but someone had already mentioned it would work with the rubber garment trimmed down & I would think it would fit being from 02 to 08 the plastics are all the same & same mounting holes except the number plate is a tad bit different but easy to make work (04 down triple clamp). As far as your suspension goes, you will get the money you need to purchase new forks if you sell the ones off your 03, just remember 48mm. Everything from what I have seen & done will work out fine.. Unless there is something im missing, it will all bolt directly up.
  • YZ-2-Strokin
Posted May 28, 2008 - 06:35 PM
Look at it from this perspective! I have parts from an 03 YZ250F, 05 YZ250F, 07 YZ 250, 06 YZ 250, 04 YZ 250 & maybe an 05 YZ 250!!!!!
Yeah, shes a mixed mutt, but I love'er.. lol
  • busted bones
Posted May 28, 2008 - 07:56 PM
Wow thats alot of different pieces together, mind explaining which ones you used from which year? I might be able to find deals on different parts.
  • rusky
Posted May 28, 2008 - 08:24 PM
there are a lot of things different between the 4 stroke and 2 stroke yami frames
  • busted bones
Posted May 29, 2008 - 12:45 AM
Ok so the frames arent interchangable but the forks are, how about the shocks though? I dont see alot about those, are the 06 shocks revised like the forks are? and will I need to get one to fit the alum frame?
  • mxjosh
Posted May 29, 2008 - 08:13 AM
Ok, since I did this I'll let you know what you need.
First, you will need a 2005+ linkage and the bolt that goes through the frame to hold it. Your 2003 bolt is too big and the wishbone on the linkage is not wide enough.
Next, you will need to buy the coil ground for the new bikes. Its just a metal bracket not expensive. A new rubber sleeve for the CDI.
You can use your 2003 clamps. If you use a newer year your 2003 forks won't work. You will have to upgrade your forks. The 2003 stops rub on the frame. So you will need to file them down about 1/4" so it clears.
The lower exhaust bracket on the frame requires a spacer so that the exhaust will line up straight. I used 2 nuts.
I did not have an issue with the rubber tank absorbers.
Lastly, the upper shock bolt has changed to the half moon style on the frame so you need this new bolt. The frame has a stopper so the 2003 bolt doesn't work.
  • YZ-2-Strokin
Posted May 29, 2008 - 11:40 AM
Yeah, there is quite a bit of mixed parts with it :thumbsup: My frame is an 04 though..
05 YZ250F forks
03 YZ250f rear shock
03 YZ250F swingarm & linkage
06 YZ 250 motor
07 YZ 250 side panels (number plates)
07 YZ 250 front number plate
05 YZ 250 seat
04 YZ 250 cdi & harness
04 or 05 YZ 250 carb
I know there is a couple others, but I just cant think of it right now.
I had another 04 then bought an 05 & switched the entire suspension & swingarm from the 04 to the 05. Only reason why I did that was because the 04 had the suspension done up from works when I had bought it.
what bike? KTM,RM,YZ,KX,or CR 125 by Numsa Hul
  • 8 replies
First Harescramble by 2000YZ250
  • Hot  37 replies
Diagnose this Piston / YZ Engine Failure by BerriosYZ
  • Hot  27 replies
How low can a dirt bike be lowered? by Numsa Hul
  • 11 replies
02 yz125 won't start by yz125MX
  • Hot  38 replies
