valve shim trouble
5 replies to this topic
  • letter
Posted March 25, 2007 - 01:57 AM
I have a 2004. I disassembled the top end to install a new piston and rings. When I took the head off, I turned it upside down to look at the valves and three of the buckets and shims fell out and I don't know their original location. Two intakes and one exhaust fell out. I have two 181 shims and a 188, a 190, and a 192. I think that one of the 181 shims was an exhaust. What should I do?
  • rexbond007
Posted March 25, 2007 - 07:24 AM
you will have to take a wild guess, assemble. check your clearance , adjust accordingly,
  • letter
Posted March 25, 2007 - 08:33 PM
Is it true that my cams will be damages because I mixed up the shim buckets?
  • yama02yz250f
Posted March 25, 2007 - 09:33 PM
just dont ride it. assemble the cams with the shims and check your valves. then mess around with the shims untill you get the clearences right.
  • rexbond007
Posted March 25, 2007 - 09:34 PM
no, but it's just good practice not to mix the buckets around.
  • rexbond007
Posted March 25, 2007 - 09:35 PM
he did not read your question
  • 0 replies
  • Hot  30 replies
  • 10 replies
