Coolant issues.Need help!!
20 replies to this topic
  • christoswr
Posted March 24, 2007 - 07:00 PM
I have an 03 YZ450 and i have a very serious issue with the coolant.I know that its normal to loose coolant when the bike idles for a while but mine needs a refill after a 20 minute session on a track.There is no leak from the radiators it comes out of the breather hose. I need to fix this asap so any suggestions would be appreciated.
  • flintlock28
Posted March 24, 2007 - 07:21 PM
The coolant level should be just below the filler neck. I followed the manual, which shows the level at the neck. If you fill it to the top of the neck, it will constantly boil over the excess, and mimic that there is a problem.
  • smokin529
Posted March 24, 2007 - 07:58 PM
Is this a new problem? If it is an over heating issue, try running Engine Ice radiator coolant. My '04 used to boil over all the time until I switched to it.
  • tacoma426
Posted March 24, 2007 - 09:14 PM
my 02 yz426 has the same prob..... it has never boiled over untill the past few rides. ...if it idles for more than one min it boils over....what could it be???? is this a problem with high hour bikes?????:applause:
Posted March 24, 2007 - 09:22 PM
Start by having your cap tested. You should be able to take only the cap to your local shop and have it done while you wait. It may simply have gotten old.
"Tired" coolant can do this, too, as can a mix that has been diluted with an excess of water.
  • tacoma426
Posted March 24, 2007 - 09:45 PM
thanks gray ill give that a try:thumbsup:
  • christoswr
Posted March 25, 2007 - 03:38 AM
I use a bottle of coolant on every track day so i dont think its tired. I'll take my cap for testing and hope for the best.
Thanks
Posted March 25, 2007 - 08:52 AM
If you're using that much, it's starting to sound like a head gasket problem. Check the cap anyway, and look for any external leaks, too.
  • christoswr
Posted March 25, 2007 - 10:33 AM
I checked a while ago for leaks but didnt see anything.I will do that again once i clean my bike and ride it for a while.Wouldnt there be any other symptoms if it was the head gasket?
  • christoswr
Posted March 25, 2007 - 10:35 AM
I'll try a 1.6 radiator cap and engine ice coolant and see what happens!
  • Crf250r121
Posted March 25, 2007 - 10:45 AM
try to get a pressure test done on the system.
Posted March 25, 2007 - 12:35 PM
There could be, but sometimes the gasket can get to leaking more coolant into the chamber than it lets compression out. That usually gets worse quickly, though. Your stock 1.1 bar cap should be enough if it will really hold that pressure.
  • christoswr
Posted March 28, 2007 - 03:17 PM
It may sound stupid but would a 1.6 radiator cap do any damage to the bike?
:bonk:
Posted March 28, 2007 - 04:17 PM
Maybe.
The numbers on the caps are in "bars". The term originally came from abbreviating the word "barometric". 1 bar is a rounded metric unit approximately equal to nominal atmospheric pressure at 70 degrees F at sea level. 1 atmosphere is 14.7 psi, but 1 bar was assigned the nice round metric value of 10 newtons/square centimeter, which is 14.5 psi.
Whatever, the standard cap, then, puts 16 psi on the cooling system. A 1.6 bar cap raises that pressure to just over 23 psi. This increases the likelihood of blowing a hose, gasket, or a radiator seam by that amount.
A higher pressure cap not only holds against more pressure, the higher pressure will raise the boiling point of the coolant.
  • christoswr
Posted March 31, 2007 - 06:19 PM
I've read the the Honda spec is 1.1 to 1.4 bar.Does anyone know whats for Yamaha's?
  • Butta
Posted March 31, 2007 - 08:20 PM
Good question.....I had a '98 WR400 that I removed the overflow bottle and replaced the radiator cap with a 1.6 (from a KX500) and never had any problems.....
  • LVThumper
Posted April 01, 2007 - 06:11 PM
That is the hot ticket for me!! 1.6 and Engine Ice!! My '01 426 still gets hot in the tight stuff with the Rekluse, but the boil over is almost gone. The tight stuff and hills I climb around LV in the summer can take a SERIOUS toll on my bike, but fresh oil every 100 miles, Engine Ice, and the 1.6 have really helped out!! :bonk:
  • christoswr
Posted April 02, 2007 - 12:24 PM
I think i will go with the 1.6 cap and engine ice but if anyone knows the Yamaha spec let me know.
  • wickoffracing
Posted April 02, 2007 - 12:35 PM
theres one of three problems it could be....one: is the radiator cap. you can have it pressure tested to see what the pop off release pressure is....your dealer or shop can test that.....two: is your head gasket. if your head gasket leaks it can leak through the outside down the cylinder, or inside into your piston and eng. oil....you'll know this when you drain your oil and its looks clumpy kinda like yogurt...and three: is your coolant level...try putting it just above your fins inside your radiator. no need to fill it all the way up cause it will leak out of your breather tube when it gets hot and builds pressure. good luck!!!
Posted April 02, 2007 - 01:58 PM
The stock cap is 1.1 bar, same as the Honda. The test pressure for a YZF is 25.6 psi, or 1.76 bar, so a 1.6 cap is OK as far as that goes.
