Making My 03 yz450 a Woods Machine
6 replies to this topic
  • jcburni
Posted March 24, 2007 - 06:49 PM
Interested in what other riders have done to their bikes to make them more manageable in the tight woods. I'm running 13/50 gears but it still is a beast in the tight trees. What have you guys and gals been doing to your suspension to make it better for the woods. Im thinking flywheel weight would help but what weight:excuseme: Any suggestions will be much appreciated:thumbsup:
  • jef
Posted March 24, 2007 - 10:40 PM
Got one, its a rocket ship ................. (left stock,) it's a matter of time before it will wrap you around a tree.
However there is a remedy: 10oz. f/w, DuBach spark arrestor or eq., and a G2 throttle - largest cam of the 3 included.
You will thank yourself you made these changes - guarranteed!
Good Luck
  • TD-3
Posted March 25, 2007 - 03:39 AM
Here is my 03 setup for offroad.
I added:
Rekluse Clutch (stock gearing)
ELine Stator
Suspension Revalve (Bruce's Suspension)
Scotts Damper
Fastway Pegs
Kickstand
Applied Rubber Mounted top clamp.
Pro Taper Windham Bend
JD Jetting
FMF Powerbomb Header
Pro Moto Sparky (not on in the picture)
Clarke 2.8gal tank (not on in the picture)
I'd say for offroading the 450, the suspension, Rekluse and damper are the best mods (in that order). If you don't go with a Rekluse a heavier flywheel weight and lower gearing will help in the tight stuff. Regardless it's still a handful, but I like it.
  • yz_for_me
Posted March 25, 2007 - 04:12 PM
I would highly recomend the Rekluse and a flywheel. The rekluse is great for eliminating stalls, but it doesn't do a lot to smooth out the power. That's where the flywheel is nice. I went with a 8 oz GYTR and have been very happy with it.
  • kawirider
Posted March 25, 2007 - 04:24 PM
I dont know if you are racing or not but I seemed to do all right with my setup. I just had 14/49 gearing with a Dr.D full system and a JD jet kit. It was quite a handful becuase I dont have barkbusters on it and my bars are really wide but I think it kinda helped me at the same time because it MADE me go fast.
I dont do singletrack very much but I was still getting up into 2nd and 3rd gear in some of the less technical sections.
I did stall it 4 or 5 times (over 60 miles) but it was purely because of my inexperiance in singletrack.
I would think that having super low gears like you do would make it much more difficult because it would be very wheelie prone....:applause:
  • jcburni
Posted March 25, 2007 - 04:34 PM
It sounds like the trails around here are a lot different then where you ride.(British Columbia). My bike is dialed for our fast trails. It's just that we also have super tight techniical trails, the kind that you don't leave first gear very often. In the summer you can charge the trails at higher speed it's just that in the winter it is the slickest train you can imagine.
I think I've decided on a 10oz flywheel for now. I just need to be able to hold a slower speed without having to feather the clutch like crazy. Don't get me wrong I do love the bull ride of the yz. I just need it to be more manageable at low speeds.
Thanks for all the help guys
  • flintlock28
Posted March 25, 2007 - 05:23 PM
I too recommend the heavier flywheel. I added a 6 oz. heavier Dr. D. flywheel (Got used) but I'd recommend the 8 oz. minimum, or the 10 oz.
  • On January 15, 2017
  • Hot  30 replies
  • 0 replies
  • Hot  113 replies
  • Hot  36 replies
