2007 wr450f oil in air box?
2 replies to this topic
  • nico-1
Posted March 23, 2007 - 08:46 PM
i have a 2007 wr 450 I did a oil change yesterday and today ride i find a lot a oil in the filter box somebody know why.
  • whooptop
Posted March 24, 2007 - 12:31 AM
maybe u just over oiled your filter I,ve done it :applause:
  • blackdog9
Posted March 24, 2007 - 06:13 AM
¡Engine oil overfill!...check "vent hose" threads. In later models, the vent hose is routed to the airbox (in a "catch can" fashion). In earlier models, this hose was open, routed as a carb drain hose... to the pavement.
I found this the hard way ...messy airbox and messy air filter. Even with a normal oil filling, after every ride I would have a dirty air filter, with a big brownish spot on its outer side. After a while I noticed this vent hose opening on the airbox... preciselly facing that brown big spot in the air filter element!!!!
So, I went the old fashion days... I plugged the hole and routed the vent hose facing the chain, as a "lube device". The result: a clean air filter after many rides, and a permanently oiled chain....(you will find that even with normal engine oil levels, the hose will still drip oil to the chain-frame after every ride).
Greetings from Chile.
Sergio:thumbsup:
P.D. Also, my bike (2007 also) would stall frequently, in low revs...and after this mod, it never stalled again. Dónt know the reason, but I´m happy again.
