Engine ice
20 replies to this topic
  • silveradoss
Posted March 23, 2007 - 08:55 AM
Have any of you used engine ice? If so how do you like it?
  • Mfinazzo
Posted March 23, 2007 - 09:01 AM
Works great and no need to mix in the water because its done for you. Your YZ should take half a bottle.
Posted March 23, 2007 - 09:27 AM
It's convenient, but it costs more than the sum of its parts are truly worth. It's basically propylene glycol coolant pre-mixed with water.
But it does work quite well, none the less. It tends not to boil out as readily as ethylene glycol mixed at 50/50.
  • 99yz400
Posted March 23, 2007 - 10:30 AM
Do you think it is worth it to pay the extra $ or is there another coolant that will do practically the same great job for less?
I heard some yz have a tendancy to overheat, what you think?
  • Mfinazzo
Posted March 23, 2007 - 10:36 AM
I'm sure you have invested allot of time and money in to your bike so why not buy some coolant that is better then the average stuff found at a gas station.:applause:
  • jayh300
Posted March 23, 2007 - 10:37 AM
mine would overheat with reg coolant. also a 99 yz400f
has not since i did the engine ice
jay
  • YZfamily
Posted March 23, 2007 - 03:36 PM
that's what I use in my bikes!
  • flintlock28
Posted March 23, 2007 - 03:47 PM
It's worth the money if you ride slow, tight trails in the Summertime. I'd occasionally get boil-over with stock antifreeze. After using Engine Ice; no more boil-over.
  • CaptainKnobby
Posted March 23, 2007 - 07:17 PM
I use in my 06 450f and no complaints
  • bdalameda
Posted March 23, 2007 - 07:24 PM
The best coolant you can buy is Evans NPG+. It is non-aqueous propylene glycol blend. Boiling point is 375 degrees. Will protect an overheated motor from damage and not boil over. Best money you will ever spend. Will also totally stop corrosion on aluminum and magnesium components. Go to the Evans web site and read about it. Zip Ty racing packages this coolant under their own name and charges double for it.
  • 99yz400
Posted March 24, 2007 - 06:26 AM
I just bought the bike and wants to do proper maintenance on it before going for a ride:ride: . I'll definetaly buy engine ice.
Thanks for your advices!:eek:
  • tammie
Posted March 24, 2007 - 01:08 PM
you could also buy a higher pressure rad cap too to help stop boil over.
http://www.pitposse....rahipr16ra.html
  • buzzgrizz
Posted March 24, 2007 - 02:59 PM
We use it and it works great!!
  • black_n_blue_thumper
Posted March 24, 2007 - 11:47 PM
I second that testimonial. :applause:
  • rexbond007
Posted March 25, 2007 - 07:52 AM
i'v used VP Cool Down with success. just add to your coolant and ride.
  • silveradoss
Posted March 25, 2007 - 05:10 PM
Thanks for all of you're feedback!!:applause:
  • ThumperKid250F
Posted March 26, 2007 - 03:02 AM
has anybody else tryed that cap and how do u like it ?
  • sandman3
Posted March 26, 2007 - 04:10 AM
I ran my bike on our DYNO and recorded the temps with reg. antifreeze,6 hours later we did it again with Engine Ice, the results were the same, I did see results when we wrapped the exhaust and the hose comming out of the water pump. I have since put a set of Fluidyne Rad's on the bike. good luck.
  • yamaha6j
Posted March 26, 2007 - 11:06 AM
I just put some in over the weekend. It seems not to boil out anymore when staging a little bit longer than I should.
  • drussell40
Posted March 26, 2007 - 04:03 PM
I run the evans in my street car and love it. What do you use in terms of a radiator cap on the car I run a 5-7 lbs cap same for a bike I have a 06 yz450
  • 10 replies
  • Hot  28 replies
  • 0 replies
