Here I go again???
5 replies to this topic
  • motopastor
Posted March 23, 2007 - 07:39 AM
I've owned an 03 & 04 YZ450...now an 07. 07 is the best motorscooter I've ever owned!!! I am having the same issues with the bottom oil filter cover bolt that I had with my other 450's??? Goes in perfect until about half way...then becomes gradually harder to thread in??? Not an issue for the first 4 oil changes...now it's 03 & 04 all over again. What am I doing wrong?
Thank you!
Monty #316
www.cfcnampa.org
  • King_Air
Posted March 23, 2007 - 07:59 AM
Are you letting the oil filter cavity drain from the bottom bolt before removing the cover?. If so dirt and shavings can get in the threads and cause your problem. I loosen all 3 bolts, then pull the cover off a little bit and let it drain that way. If you do a search I think you will find more info on this.
Posted March 23, 2007 - 09:21 AM
http://www.thumperta...786#post3897786
http://www.thumperta...288#post3823288
  • motopastor
Posted March 23, 2007 - 11:13 AM
Thank you!!!
  • rideawn
Posted March 26, 2007 - 11:39 AM
Thank you!
Monty #316
www.cfcnampa.org
I was having this same issue also. When doing just an oil change, no filter, I think the book recommends pulling just the lower filter cover bolt?
Posted March 26, 2007 - 01:38 PM
Read the link I posted. That procedure is the root of this kind of problem.
  • 5 replies
  • Hot  28 replies
  • Hot  47 replies
  • Hot  36 replies
