Why put maxima 927 oil in a 4stroke gas tank?
42 replies to this topic
  • CaptainKnobby
Posted March 21, 2007 - 07:55 PM
What is the purpose of a teaspoon of maxima 927 oil in a full tank of gas in a 450 fourstroke. Does it help the valves or something else?
  • rmz757
Posted March 21, 2007 - 07:56 PM
from what i have heard, it helps the valves, and the piston/cylinder because it provides just a little more lubrication. plus it smells nice :applause: haha
  • CaptainKnobby
Posted March 21, 2007 - 08:19 PM
I'll try it! "I like the smell it gives off" Would you do this often or just once every tank of gas?
  • 250Thumpher
Posted March 21, 2007 - 08:44 PM
Not sure about that product, but I run Marvel Mystery Oil.
Lubricates the top end and carb, helps fight breakdown of fuel, and the fuel doesn't stink as much...
  • witdogg
Posted March 21, 2007 - 10:41 PM
I have never heard of anyone doing that. I am going to try it now though.
  • TexN343
Posted March 22, 2007 - 12:03 AM
Would this richen the fuel enough to justify rejetting or just turning the fuel screw leaner a bit?
  • ThumperKid250F
Posted March 22, 2007 - 03:21 AM
i mix it 100 to 1 in my 50 50 race / pump gas
a teaspoon wont do nothing
  • CaptainKnobby
Posted March 22, 2007 - 04:51 AM
How much of the maxima 927 would you add to 5 gal.'s of gas?
  • SUnruh
Posted March 22, 2007 - 04:56 AM
you boys need to do some searching for a post from Tryce (ffrracing) about using MMO and how it helped with his dirttrack yzf motors. the boy has been roundy-round enough to listen to. if you understand, all the better. :applause: :eek:
  • Wiz636
Posted March 22, 2007 - 07:51 AM
A teaspoon added to a tank of gas is just for the smell. Any castor-based pre-mix oil should work.
  • jaydizel
Posted March 22, 2007 - 08:16 AM
http://www.thumperta...ad.php?t=485338
i put cap full in a half a tank.
jason
  • Ga426owner
Posted March 22, 2007 - 12:36 PM
I am not sure that I agree with all this........unless you plan to let your bike sit for a while. :applause:
Posted March 22, 2007 - 01:42 PM
This arose out of the thread:
(also posted above this) in which it was asked if there was an oil for 4-strokes that smelled like castor, and there is; oddly enough, it's castor. But it's impossibly expensive to buy as a four-stroke lube oil in any form I'm aware of, so if you really have to have that smell, adding it to the gas as a "top oil" is the only other choice.
The use of top oils are a very old school practice, but still has some merit. Modern valve seals and oil rings are so effective that they exclude virtually all oil from the upper cylinder, and the compression rings, valve faces, and valve stems in your bike are lubricated almost entirely by gasoline. The aforementioned gentleman some of us know as T-Dub would point out that some racing fuels tend to be a little bit too "dry", which is to say that in his opinion, they don't have enough lubricating properties to make him comfortable. Adding oil to the fuel at a rate of 10-15cc/gal (around 300:1), or more, is one way to restore that lubrication.
As a top oil, Marvel Mystery Oil is probably a better choice than a two cycle castor, because it has cleaning properties the castor doesn't, and is somewhat cleaner burning than castor in any case. If you just like the smell, there's no harm in doing this as long as you don't put so much in the fuel that it starts smoking and fouling plugs. Back in the day, we ran Castrol R in all our big British bikes, and you could always smell it in the exhaust just from the small amount of oil that got past the rings and valves, so it takes very little for your nose to pick it up. 5cc a gallon (one teaspoon) should be enough. That's about 750:1, BTW.
  • yamaha_4_eva
Posted March 22, 2007 - 02:15 PM
so if im correct, its the maxima that makes it smell good?
  • Dr.Crankenstien
Posted March 22, 2007 - 04:07 PM
Yes.
Maxima 927:thumbsup:
  • CaptainKnobby
Posted March 22, 2007 - 04:17 PM
Does th marvel mystery oil give off the smell to.
  • yamaha racing 230
Posted March 22, 2007 - 05:40 PM
ive noticed no smell when i added mmo to my gas tank but if u smell it out of the bottle it smells kind of minty.
  • CaptainKnobby
Posted March 22, 2007 - 05:54 PM
I guess i'll get some maxima 927 and put one teaspoon to 5gal of gas. I dont think that will be to much to foul a plug or make it run to rich "do you".
  • ThumperKid250F
Posted March 22, 2007 - 06:43 PM
not at all. i run 50 50 race and pump gas in my bikes and i mix my gas with the maxima at 100/ 1 ratio. my bikes run great, no fouling plugs and it does not run rich.
  • jeffboyd47m
Posted March 22, 2007 - 09:55 PM
Adding oil to gas makes it run leaner not richer, although the amounts that you are talking would have no noticeable effect on your bike
  • Hot  113 replies
  • Hot  50 replies
  • Hot  47 replies
  • 9 replies
