Which oil to use????
11 replies to this topic
  • TyeeHusky
Posted March 21, 2007 - 11:34 AM
If you read the manual it calls for the following tranny oil for the 07 WR450
Using Yamalube:
Up to 70 degrees 10w-30
50 degree and up 20W- 50
Does not sound like there is alot of overlap. I do not like the idea of the 20W to to engine wear while it is cold and thick. How about just running a high quality 10W-40? This will cover the low temp and high temp. Manual shows 10W-40 in the lower graph but not made by Yamaha. What oil are all you running? I cannot believe that Yamalube is any better any other high quality oil.
Any feedback?
  • waynus
Posted March 21, 2007 - 12:22 PM
A high quality 10/40 would be fine, or a 10/50 if it gets hot. You might want to do some reading on Shell Rotella.
I run Delo 400 in mine and my roadbike with zero clutch slippage. It is a 15/40 high quality mineral oil. In your climate though I think you are prolly better off with an initial 10.
  • clark4131
Posted March 21, 2007 - 12:37 PM
Amsoil 10/40 full synthetic with a Rekluse :applause:...Guess what? No slippage!!!...SC
  • SJMC_DON
Posted March 21, 2007 - 01:43 PM
I've been running the Maxima syn-blend 10-40 for quite a while now and it has proven to work best with the clutch issues I was having on my 04'
In Western WA, all year long....
  • Farmerboy
Posted March 21, 2007 - 01:49 PM
i use 10-40w fully synth in the uk on a wr450 05 model with no issues at all
  • Fullbore4
Posted March 21, 2007 - 10:17 PM
Using Yamalube:
Any feedback?
Correct me if I'm wrong but the following page is for an 07WR450 (top graph for USA/Canadian) and it lists 10W30, 20W40 and 10W50 respectively:
  • Seabass
Posted March 22, 2007 - 08:40 AM
Mobil1 and no problems. Didn't Rotella and Dello oils get an additive that is not good on the clutch?
  • Vegemite_luva
Posted March 22, 2007 - 09:05 AM
I looked at the Shell.com site and it looks like Rotella is regular synthetic oil for cars and trucks. Can you use this type of oil in a motorcycle?
  • SJMC_DON
Posted March 22, 2007 - 10:57 AM
Must be free of any friction additives as I understand it:excuseme:
  • waynus
Posted March 22, 2007 - 11:25 AM
Here is the link http://www.shell.com...expert_faq.html
If it was available in Oz at a reasonable price like it is in the States, I would use it in a flash. :applause:
  • waynus
Posted March 22, 2007 - 11:30 AM
Moly seems to be the main concern. Rotella doesn't have it. Delo has @ 220 ppm (parts per million). I've had no clutch problems at all using Delo and actually prefer the added peace of mind knowing moly is in there for extreme protection.
  • SXP
Posted March 22, 2007 - 11:45 AM
I've used Shell's Rotella 15W40 (dino) or Chevron's Delo for the past 15 years in my street and dirt bikes with absolutely no issues. The street bikes (a 1100 and a 650) go 2000 miles between changes, and my dirt bikes (WR400, XR400 and KLX 250) go 300 miles between changes and the 07 WR450 about 150-200 miles between changes. If you change the oil often enough you shouldn't have an issue.
