Valves - Riding when mal-adjusted.
6 replies to this topic
  • Esrum1
Posted March 19, 2007 - 07:38 PM
I just did a valve job on my 2005 XR650R. 6 months ago, I got them spot on. Unfortunately, they tightened up a bit, so I loosened them, but I loosened them too much this time around. I'm now getting the annoying clanking from the loose valves.
I probably won't have time to re-adjust them until this weekend, but would like to ride tomorrow to work. Is this generally a bad idea with loose and loud valves?
I should probably stick with my own intuition that tells me just to let her sit until I get it right.
Joe
  • bork
Posted March 19, 2007 - 07:45 PM
Always better too lose than tight. Too tight burns valves, thus leakage from warp or pitting.
  • HawkGT
Posted March 19, 2007 - 08:28 PM
What's that old saying? "A noisy valve is a happy valve"
Obviously the correct spec is the best thing but too loose is safer then too tight.
  • hawgman94
Posted March 20, 2007 - 07:00 AM
"a Slappy Valve Is A Happy Valve"
  • HawkGT
Posted March 20, 2007 - 08:15 AM
That's it! :applause:
  • OUTERLIMITS
Posted March 20, 2007 - 12:44 PM
They're so quick to adjust, why not just make it right and ride. I had the same issue because I wanted to adjust them to the "safe side", but the extra clatter was too much. I redid it before the next ride and got it spot on and it's nice and QUIET now.
  • Billahjack
Posted March 21, 2007 - 07:11 PM
I adjusted my valves 3 times in the same day when I put a new cam in. The first time the moly lube got in the way and they were loose. The second time I was just retarded and they were loose. The third time I developed a technique for tightening the jam nut while maintaining the proper clearance and they are good now.
