plastic clean up....
10 replies to this topic
  • pudadin
Posted March 19, 2007 - 01:02 PM
Can anyone tell e the product that cleans scratches and scuffs from plastic(fenders....)? Does it work?
Thanks!
  • trailordune
Posted March 19, 2007 - 01:14 PM
Plastic renew by PC Racing and in my past experience no it doesn't work so well. It's alot of work and the plastic is left dull but I did lose interest after the first bad result. I'm sure it could turn out pretty nice with enough effort. Just not for me. Plastic is pretty cheap for these bikes.
  • byggd
Posted March 19, 2007 - 01:15 PM
I tried a product called plastic renew. It was a LOT of sanding and IMO it didn't last long enough to make it worth the time.
http://shop.thumpert...fault.asp?p=906
  • pudadin
Posted March 19, 2007 - 01:38 PM
Thanks! What is the best way to clean plastic? Wet sand 200 grit? I have some gas tank stains that do not merrit a new tank...just looks like heck!!!!
  • WildRide
Posted March 19, 2007 - 07:28 PM
Furniture polish (aka. pledge) works as good as the motorcycle specific stuff and cost a lot less (especially when on sale). It will never look "new" again though. Careful heat gun work will diminish the white fatigue marks quite a bit.
  • snoprof7
Posted March 19, 2007 - 07:47 PM
polish it with a palstic rouge be sure to press hard and use the correct pad.
dont press to hard but just enough so it will get warm.
  • bud1970
Posted March 20, 2007 - 07:22 AM
Spend alot more time riding than polishing your plastic parts. Plus new plastic usually only cost $20 to $30 bucks
  • MSHAM
Posted March 20, 2007 - 08:02 AM
Try Futura acrylic floor wax! apply with soft cloth directly from the bottle. Let dry, looks wet!:applause:
  • 89TRX350RX
Posted March 26, 2007 - 02:10 PM
Try using a household cleaner called "Vim" to clean it and follow it up with the "Futura" floor wax or something similar... Thats what my buddy uses on his Honda.... Can't ride it, might as well make it look like new... Not even sure how he managed to get it scratched/dirty in the first place... Musta bin dust from his garage!!! Anyhow, enough bashin the Red Bikes, but it made it look good, almost as good as putting NEW plastic on it...
Jamie
  • TWILES
Posted March 26, 2007 - 03:46 PM
I got a bottle of Armorall once that had directions for use that said to mist it on and let it set 30 minutes 3 times and after that mist it on and whipe it off right then for first time use. I did this to my 89 Honda 250R when I bought new rear plastic and the front was OLD. It wasn't from 89 because it was red but it had been on there a while. The next day the front ( guess it had to soak in ) looked as good as the NEW rear. I haven't seen those directions on any other bottle since but you might try it.
  • Just_a_trail_rider
Posted March 26, 2007 - 05:11 PM
I agree. On my white plastic, I usually use just a little bit of gasoline to remove all of the scuff marks. Trust me, gasoline will remove 99% of everything.
I also use just a little heat to remove the stress marks. Take the plastic off, and heat it up from the back. Don't get carried away.
Scratches are like badges of honor though. Each one has a really good story associated with it. Its a dirt bike!
