04 subframe
1 reply to this topic
  • Toyuki
Posted March 19, 2007 - 10:23 AM
my 04 wr lower right side subframe mount, has some play in it. you can push down on the seat and see it move! the bolt was worn, I replace it and torqued it down, but it still had play! the hole on my subframe must be elongated. if I drill it out and put a steel bushing in it would it hold up? and what would cause this?
  • Indy_WR450
Posted March 19, 2007 - 06:28 PM
Buy the steel wr426 sub frame. I am on my 2nd aluminum sub frame because the holes do elongate. You can try and have it rewelded and drilled. There is not enough meat for a larger hole and bushing.:applause:
