BD Baffles?
1 reply to this topic
  • beerjonny
Posted March 19, 2007 - 08:49 AM
:applause:
I need to quiet the stock pipe I got with the bike (came with no guts at all).
Only thing I can find to fit in the stock pipe is the Baja Designs Baffles:
http://shop.thumpert...fault.asp?p=636
I was hoping to find a replacement for the spark arrestor, or some type of quiet insert for the stock can. Hell, I'd even take A stock insert, if they weren't $150 OEM :eek:
  • XRR-kat
Posted March 19, 2007 - 04:53 PM
beerjonny,
Unfortunately, the BD baffles need to be used with the HRC tip. I couldn't see how that would work (nor could I even find a BD baffle) but now that I have an HRC tip, the BD baffle tip (three different length tubes cut at approx 45 degree angle and fitting in a pipe about the diameter of the HRC tip and with a flange around it) would fit inside the HRC tip.
Good luck,
