Valve Job. What parts to order?
7 replies to this topic
  • slowxr
Posted March 18, 2007 - 07:51 PM
I've got a friend that's helping me with my valve job.
He said to get on Service Honda and order the parts.
Intake/exhaust valves, springs, head gasket.
What else do I need.
Thanks in advance.
  • JackAttack
Posted March 19, 2007 - 06:44 AM
Your cam chain may have stretched. Depending on the hours, you should probably replace it.
Also, depending on the hours, you should do the piston rings while your in there. Inspect the cylinder and it should be fine, and just throw in a new set of rings.
  • creeky
Posted March 19, 2007 - 07:05 AM
Kibblewhite valves and springs are superior to the Honda OEM.
  • cleonard
Posted March 19, 2007 - 10:42 AM
The tensioner failed on mine. It worked great with the engine just sitting there, but allowed the chain to get loose when running.
Be watchful for valve seat problems. XR's only can make and install a replacement it is shot or loose in the head.
Service Honda may have the best prices, but they are slow and charge a lot for shipping. Try and get everything in one order.
  • slowxr
Posted March 19, 2007 - 02:20 PM
I called Precision Concepts in El Cajon.
They recommended a complete top end since I'll have the top opened up.
They said valves, piston, new rings etc for about $700(parts and labor). Sounded pretty reasonable.
Anyone have experience with their work?
  • rebelventurer
Posted March 19, 2007 - 05:56 PM
No one has mentioned valve guides, seals, retainers, rockers, camshaft, or replacing the piston with a higher compression slug? :applause:
  • XR4DEZ
Posted March 20, 2007 - 09:19 AM
These guys are top notch, everything will be done perfectly.
  • blacktdi
Posted March 20, 2007 - 10:54 AM
Don´t forget the camshaft middle bearing when worn out. My local machine workshop did an excellent job. Always replace the camchain and tensioner while you´re there.
  • 9 replies
Honda XR650L 2017
  • 0 reviews
  • 4 replies
  • 17 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
