"Brakes for Dummies" question
9 replies to this topic
  • drtbk4ever
Posted March 18, 2007 - 05:04 PM
Hey Gang,
I am a complete noob when it comes to brakes so please excuse my ignorance. I just finished greasing swingarm and linkage. After I put the rear wheel back on, I was checking the operation of the rear brake.
It seems the brake pads do not retract much after I let off the pedal. So I did numerous searches. I believe my issue is the calipers and seals have some dirt/mud clogged up there from last years rides.
This photo doesn't show the brake pads dragging, but it's the only photo I have of the rear brake.
So I did more searching and reviewed the manual and didn't find the answer so I'll ask you, in order to get to the calipers, do I HAVE to drain the brake fluid? I don't really want to have to replace the fluid and bleed the lines unless I really have to.
Any input is greatly appreciated.
Cheers.
  • 450high
Posted March 19, 2007 - 12:56 AM
disk pads always rub.As long as you can spin the wheel it's o.k
dave
  • drtbk4ever
Posted March 20, 2007 - 05:29 PM
dave
Hi Dave, thanks for that info. I can still turn the wheel. I can understand the pads rubbing as it is a floating disk system. My concern was with the caliper pistons (I think they're called) not retracting much at all. I'm under the impression the caliper pistons would retract somewhat and the pads would float.
Am I incorrect in that assumption?
  • racejmac
Posted March 20, 2007 - 07:26 PM
They should not travel as far as you think...
think about it for a minute... Long travel equates to longer stroke on the master cylinder witch is applied by the pedal...
If the wheel is hard to turn by hand that would suggesst and issue. If it spins okay with a little pad hiss... Your good... Go ride and analyze the terrain in front of you instead of the bike while it sits on a stand...:applause:
  • drtbk4ever
Posted March 21, 2007 - 07:47 AM
OK, that makes sense.
I'll check on this again.
I would love to go for a ride, however, the foot of snow still on the ground means analyzing the bike while it sits on the stand is my only alternative for the next couple of weeks.
Thanks for the input.
  • Farmerboy
Posted March 21, 2007 - 01:44 PM
a foot of snow is the main reason you should be out riding, I did for the first time last month in the UK when we had some good snow,
It was the most fun ive had for years on a bike - just go steady and enjoy the slide
  • drtbk4ever
Posted March 21, 2007 - 03:13 PM
Once upon a time I would have studded up the tires and been riding all winter. Now I am just a wimp.
  • marty b
Posted March 21, 2007 - 03:25 PM
there is no relese mech. at allfor a disc brake, it relies on movment of the rotor to move the pads back into the caliper, the faster the didc is turning the more it moves. the floting caliper is to compensate for uneven were on the pads so both sids contavt evenly
  • WR_Dave
Posted March 21, 2007 - 05:01 PM
Hey Bill, the caliper piston will only retract enough to release the clamping pressure on the disk. The caliper is only forced back into the housing as far as the size of the disk taking into account any warpage. There aren't any retraction springs like you find in the drum brake systems. All these things are what makes disc brakes stonger and better in all ways than drum type brakes. :applause: WR Dave.
  • drtbk4ever
Posted March 21, 2007 - 07:14 PM
Thanks for all your help guys. I will now sleep better.
Cheers.
