excel rims brake fitment
19 replies to this topic
  • Type Gendy
Posted March 18, 2007 - 07:42 AM
I bought my 426 over the winter and dont know all that much about it. It has some excel rims on it i guess, and one of the things i noticed is that the rear brake caliper doesnt fit well. Only about half of the pad is making contact with teh disc? Is this a common issue? What can i do to fix this ?
Posted March 18, 2007 - 08:20 AM
Measure the diameter of your disc for me.
It should be about 245mm, or 9 3/4". That doesn't look like a 426 rear rotor.
  • Type Gendy
Posted March 18, 2007 - 11:37 AM
Looks the rotor is about 9", so i guess that explains why it doesnt go all the way up into the caliper?
The outside diameter of the hub looks to be about 4.75"
  • ____Kurt____
Posted March 18, 2007 - 12:12 PM
that hub/rotor looks like it can be for a different bike because those aren't even teh stock 426 spacers. at 9" thats only 228.6 (1"=25.4mm) and thats what it looks like. i would suggest if you don't want to get a new hub to fix the problem which could be expensive try to find out what hub that bike is for. because you might be able to get a bigger one (doubt it though).
im not too sure on how to fix it with out making different mounting brackets for the caliper or getting a new hub at the moment. that is a nice hub though :applause:
  • Type Gendy
Posted March 18, 2007 - 06:59 PM
what is not the stock "yamaha space" ?
wonder if i could get another rotor that was bigger in diameter that would have more contact with pads? who knows what bike to order it for tho :applause:
  • Type Gendy
Posted March 20, 2007 - 12:34 PM
REally wanna straighten this out :applause:
Posted March 20, 2007 - 12:48 PM
See if the diameter of the shoulder on the hub that centers the rotor is the same as a YZ/YZF. If it is, then just using a YZF rotor will solve this. If not, a good guess would be a Honda, going by the numbers. If you could determine which model, you could then see if there is an oversized rotor available, or a later, larger one.
  • Wiz636
Posted March 20, 2007 - 01:19 PM
Nice looking hub but that's definitely not a stock Yamaha wheel spacer (the spacer between the hub and the brake caliper). I would just do like Gray says and measure the rotor mounting shoulder on the hub and make a phone call to a disc manufacturer like EBC or Galfer and see if they can get you set up correctly.
  • ouelto
Posted March 20, 2007 - 02:08 PM
all yz yzf have the same disc brake size for years , are you sure your wheel are for a yz? it look like a kx size disc brake,
  • Type Gendy
Posted March 20, 2007 - 07:32 PM
No i'm not sure, like i said i bought the bike as is and know nothing about the setup. I was suppose to get the stock rims with new tires too, but never got a hold of them.
The rear tire still locks up, but for some reason just doesnt feel like i have as much control on it
  • ouelto
Posted March 21, 2007 - 05:34 AM
i remember a guy here tried to put a kx wheels on a yz and had the same result as you ,disk brake was to small
is there a serie # or something on the hub just to see if its really for a yz?
  • Type Gendy
Posted March 21, 2007 - 05:53 AM
Good idea, but i dont think so. I'll take a closer look at it later
  • drtrcr400
Posted March 21, 2007 - 06:50 AM
Call Galfer or EBC with the dimensions and bolt spacing of that rotor. They should be able to tell you what hub that is and whether or not they make a rotor that fits.
  • TotallyMetal
Posted March 21, 2007 - 07:58 PM
I agree.. How often are you on the rear brake to worry about it. Does it work when you need it? I like the hub, the disc is definitely from something other than a YZ. I don't use much more than that on my Galfer rear disc, check my garage.
  • Type Gendy
Posted March 23, 2007 - 11:02 PM
It locks the rear up, so is that all i should really be concerned about?
I'm just such a perfectionist things like this bother me :applause:
  • Type Gendy
Posted July 16, 2007 - 05:39 AM
ok guys, did some reseach and a bit of an update... i sent email to talon and here was their reply:
Dear Gendy
Thank you for your E-mail. I have spoken to Richard in the Wheel
Department who confirms the
following information:
Please find below the following information as requested:
Hub No: 18643 - Yamaha YZ 400 front gold hub built for White Brothers on
06/07/1999.
Hub No: 30988 - Yamaha YZ 1999 rear gold hub built for White Brothers on
08/02/2000.
Please note on your Yamaha YZF 426 2001 bike you will have a 240mm
diameter disc, you require a 245mm disc - TD212D.
Please note if you wish to purchase the above disc then please could you
contact White Brothers who are our US importer. I am sure they will be
able to assist you with your requirements.
Ken Davie
White Brothers
24845 Corbit Place
Yorba Linda
C.A. 92887
U.S.A
Tel No: 001 714 692 3404
Fax No: 001 714 692 3409
E-mail: kdavie@whitebrothers.com
If you have any queries regarding the above then please do not hesitate
to contact me.
I look forward to hearing from you.
Many thanks
Justine Richards
TALON ENGINEERING LTD
44 LYNX TRADING ESTATE
YEOVIL
SOMERSET
  • Ga426owner
Posted July 16, 2007 - 05:52 AM
I have a slightly used stock rear disk if you need it.
I will check to see what size it is - it came off of a 03 yzf 450 - I believe it is the same as a 426 but will verify
  • Type Gendy
Posted July 16, 2007 - 11:42 AM
awesome, thanks man! :thumbsup:
  • Type Gendy
Posted July 16, 2007 - 12:08 PM
ok, scratch that
According to chaparral the 426 and 450 are different
http://www.chaparral...A1243EEE1DF2B51
  • moto2000
Posted July 16, 2007 - 04:26 PM
I have one from an '01 426 if you need.....shoot me a PM :thumbsup:
  • 9 replies
  • Hot  47 replies
  • 0 replies
