How to change CS Sprocket on a 650L?
5 replies to this topic
  • uberhada
Posted March 16, 2007 - 11:56 AM
Hi, Im new to the forum, just bought a 2007 XR650L.
Just finished the IMS Blockoff kit, snorkel removal, foam filter, doing the jetting now.
Im getting a factory manual soon, but want to put a 14T sprocket on to hit the dirt this weekend, and want to do it right.
Any have instructions on how to do this?
  • frankiewhipit
Posted March 16, 2007 - 12:45 PM
remove the two 10 mm bolts & the plate they're holding on, swap sprockets, loctite the bolts & reassemble :applause:
  • cleonard
Posted March 16, 2007 - 01:26 PM
You may need to readjust the chain slack. Since the 14 is smaller the chain will have a little more slack. I don't remember the spec, but too loose is better than too tight.
  • uberhada
Posted March 16, 2007 - 09:19 PM
Love this forum :applause:
Thanks guys!
  • Jawmail
Posted March 17, 2007 - 04:38 AM
What do the bolts get torqued to. The manual says 7 ft-lb for 6mm bolts ? Doesn't seem like much. The thread measures 6mm across the threads. You will have to adjust the chain, it's quite loose after the swap to 14 teeth.
  • cleonard
Posted March 17, 2007 - 05:58 AM
The 7 to 9 ft-lbs if for a 6mm fastener into aluminum. The sprocket is steel and should be able to stand up to a little higher torque. I don't have my book handy though. This is a good place for loctite as well.
