Regina Chain 520 ORN-6 versus 520 ORS-6
9 replies to this topic
  • toofast2
Posted March 16, 2007 - 07:31 AM
What is the difference between the two?..other then tensil (ORN is 7644)&
(ORS is 8093)and price is more for the ORS,other then that what's the diff.?
GrayRacer can you weigh in here?..THX ED:ride:
Posted March 16, 2007 - 07:53 AM
You have it figured out already. It's marginally stronger, and costs more. The ORN-6 is all you need.
  • toofast2
Posted March 16, 2007 - 07:58 AM
Grayracer,thank you very much,I assume the only difference between the two
is different metal,thickness in the sideplates are the same?..correct?
also stock chain on a '06' YZF450 with stock gearing is 114 links?
Posted March 16, 2007 - 08:09 AM
No. The plates are thicker, and the chain is 0.8mm wider overall. It's also slightly heavier. For that, you go from 7600 psi to 7900? Not worth it.
All that info is on the Regina site, which is something you don't generally see with other chains. Mine has more wear on the "top" (the vertical outside edge of the plates) from dragging through dirt in the chain guide than anywhere else. At this rate, that may be the thing that finally gets it off the bike.
http://www.reginacha...scheda_or.shtml
  • toofast2
Posted March 16, 2007 - 10:29 AM
Gray,I knew I was talking to the right guy!..That's exactly the info I needed!
Thank You!...how do I find out how many Link chain is on stock bike(114?)
is it in the shop manual?..or would it be on yamaha's website...I really don't
want to get a larger chain and cut/grind the rivets,I have no intention in the
future to change gearing.Thx again ED
Posted March 16, 2007 - 01:09 PM
Stock is 114. I always buy a 120 and cut it to fit.
  • toofast2
Posted March 16, 2007 - 05:08 PM
Thanks Gray,114 it is,by the way,when do I get my " TT newbie" removed?,
after how many Posts?? THX ED
Posted March 16, 2007 - 09:13 PM
From the FAQ page:
http://www.thumperta...faq_user_titles
  • Wiz636
Posted March 17, 2007 - 12:41 AM
When you're not a newbie anymore. The mods vote once a week.
  • Wiz636
Posted March 17, 2007 - 12:43 AM
...and when you don't have a quad in your avatar
