oil capacity of a '00 yzf426??
2 replies to this topic
  • Yosemite Sam
Posted March 16, 2007 - 05:44 AM
Can anyone out there tell what the gear iol capacity is of this 426? A friend just got one w/o the owners manual and needs to know. thanks
  • ____Kurt____
Posted March 16, 2007 - 06:27 AM
this is for an '01 Yz426F. i doubt the oil amount needed has been changed but i can be wrong. add the following amount and check your dipstick. good luck :thumbs up:
____________________________
|Oil quantity:..........................|
|Total amount: .......................|
| 1.7 L (1.50 Imp qt, 1.80 US qt)|
| Periodic oil change:................|
| 1.5 L (1.32 Imp qt, 1.59 US qt)|
| With oil filter replacement:.......|
| 1.6 L (1.41 Imp qt, 1.69 US qt).|
|____________________________|
Posted March 16, 2007 - 08:21 AM
The engine oil is the gear oil, and vice-versa. You will need to familiarize yourself with the oil change procedure, because it's a dry sump system, and if you do it wrong, you'll make trouble for yourself.
Here's some instructions for the 250F (same procedure, use the info for the early model):
http://www.thumperfa.../oil_change.htm
And here's a link to download a manual:
http://www.yamahaown...ook.com.au/?r=0
  • On January 15, 2017
  • Hot  36 replies
  • Hot  47 replies
