XR650R swingarm bearings.
5 replies to this topic
  • dino2000
Posted March 15, 2007 - 02:17 PM
how do i get to these things to service them. do inedd some special tools. anyone done it?
Thanks in Advance, Dino
  • gchidest
Posted March 15, 2007 - 03:46 PM
Dino200, just did my swingarm bearings this week. I removed the linkage from the shock and pulled the swingarm bolt out. I could not get the swingarm off without the swingarm preload bearing tool. I ended up making the big tool out of an 1 1/16 socket with the help of the pig pen website. I had the small tool for the swingarm from honda. Once loosened, swingarm came out. One bearing was pretty bad, but after a good cleaning and greasing, I was satisfied. The tool isn't to hard to make if you have a dremmel tool and cut off wheels. I used some foam that you get from craft stores for flower arrangements and pushed it into the swingarm. It left a perfect indention that was used as a pattern for the socket.
  • XR4DEZ
Posted March 15, 2007 - 08:32 PM
Dino200, just did my swingarm bearings this week. I removed the linkage from the shock and pulled the swingarm bolt out. tool. I ended up making the big tool out of an 1 1/16 socket with the help oI could not get the swingarm off without the swingarm preload bearing f the pig pen website. I had the small tool for the swingarm from honda. Once loosened, swingarm came out. One bearing was pretty bad, but after a good cleaning and greasing, I was satisfied. The tool isn't to hard to make if you have a dremmel tool and cut off wheels. I used some foam that you get from craft stores for flower arrangements and pushed it into the swingarm. It left a perfect indention that was used as a pattern for the socket.
Did you have any trouble removing the swingarm bolt?
  • gchidest
Posted March 15, 2007 - 10:17 PM
i pounded it out with a rubber mallet. Afterwords, I cleaned it up with a wire wheel.
  • prockish17
Posted March 19, 2007 - 11:17 AM
Take it from someone who did not grease these bearing. I was 82 miles into an 85 mile race and the bolt snapped at the linkage/swing arm. The bolt was cut by the needle bearings. I had to push for 2 miles to find a road, worst day of my life. Do check and lube all these bearings. This cost me nearly $1k in damage. It is a bit of work to get in there but needs to be done, not often just done. :applause:
  • dezracerE
Posted March 19, 2007 - 02:46 PM
Honda does not add any grease to their bearings due to shipping issues. (they do not want any grease or oil falling from their bikes or they will be fined-what I was told by a Honda rep). The only grease on the bearings is from the manufacturing process. If you take apart a new bike- they are very dry. You need to grease even when new. Sounds like you learned the hard way. The parts should come apart fairly easily if lubed. If the swingarm bolt is very tight-it is stuck to the bearing sleave-no bueno.
Check your head bearings also...
