DRZ Chain
13 replies to this topic
  • djrowe
Posted March 13, 2007 - 03:28 AM
Hi guys - just got an '05 DRZ400s to replace my '03 XR250R and thought I'd pose a question. I'm thinking of swapping the 15t cs sprocket on my DRZ for a 14t just to give a bit more low-mid range zip. While I was at it I thought I'd take the chain off and give it a clean. Checking the owner manual it mentions that the chain is an 'endless' type with no master link and should be removed only by removing the swing-arm and should only be done by a Suzuki dealer. Can this be for real ? It also says not to replace with a master-link type chain ? I find this hard to believe - I assume most people have probably removed the chain using a breaking tool and installed a master-link ?
Any comments/opinions ?
Cheers
Dave
  • William1
Posted March 13, 2007 - 04:48 AM
You can cut the chain.
You can use a properly installed master link.
Clean the chain with kerosene.
  • Regalman
Posted March 13, 2007 - 05:05 AM
Many bikes come from the factory with an 'endless chain'... If it were me, I wouldn't break it just to clean it. A master link is just one more thing that can go wrong in middle of nowhere. [when installed properly, it shouldn't, but you never know]
  • William1
Posted March 13, 2007 - 05:21 AM
On a small bike like the DRZ, the endless chain not needed due to power output. It is a more secure chain per Regal's comment. I suspect it is that reason and the fact it is $.12 cheaper to buy and one less step in the assembly process.
  • Regalman
Posted March 13, 2007 - 05:25 AM
...and probably one less liability. If the robot didn't get the master link on correctly and someone dies as a result Suzuki would get thier pants sued off.
  • MotoChris521
Posted March 13, 2007 - 05:28 AM
Why do you need to clean the chain ? The stocker is an O ring. Lubing the outside and wiping it down with a shop towel isn't enough ?
  • kman780
Posted March 13, 2007 - 06:16 AM
That explains why I looked for 20 minutes for my master link and couldn't find it.... :applause:
  • GuyGraham
Posted March 13, 2007 - 06:46 AM
Rivet link is available as an OEM spare from your local suzuki dealer, for the std chain
in the UK it is £8
  • Motomike1
Posted April 06, 2008 - 03:12 PM
how do you make the chain shorter without breaking it??? I want my chain, just shorter so i can put on a smaller rear gear!!! Right now there's too many links.
  • Erik Marquez
Posted April 06, 2008 - 03:21 PM
Grind off the heads of the link you want to remove, pop the said plate off, and the other side of the link will come right off.
Even is you have a press, you should grind the flattened rivet head off first.
  • Motomike1
Posted April 06, 2008 - 03:35 PM
so then if the head is grinded off, then what is going to keep the cahin together once it's re-assembled?
  • rustyknife
Posted April 06, 2008 - 03:47 PM
You'll have to buy a master link
  • Cuchara Red
Posted April 06, 2008 - 04:41 PM
Do NOT use the link you've removed. No way, nada, nay nay. Disaster awaits you if you even think about it!:thumbsup:
  • hometheaterman
Posted April 06, 2008 - 07:42 PM
I have a RK chain on mine with a master link I'm pretty sure and I haven't had a problem in the years I've had it. *knock on wood*
DRZ400s front fender swap for highway? by webbie1
  • Hot  35 replies
Think a DRZ can plow through 30" of snow? CABIN FEVER by kevvyd
  • Hot  37 replies
DR350 Top end rebuild? by Tobyperkins17
Dirt Bike   Make / Model Specific   Suzuki   DR
  • 10 replies
Huksy 701 by rraiderr
  • Hot  50 replies
Death wobble still 2014 DRZ400S by BadBob
  • Hot  30 replies
