Linkage/Swingarm "string cheese" questions
18 replies to this topic
  • drtbk4ever
Posted March 12, 2007 - 02:43 PM
Hello Gang,
I am going to attempt to lube my swingarm and linkage this weekend and am unsure about something. The link at ThumperFaq gives a detailed explanation about the string cheese in the linkage bearings, but makes no mention of the Swingarm bearings.
http://www.thumperfaq.com/swingarm.htm
Will I find the "string cheese" in the swingarm bearings?
Can I repack the bearings without removing them from the swingarm?
Or should I just take the beast down to the local dealer and let them do it?
Thanks from a newbie when it comes to bearings.
  • 1BLUEsky
Posted March 12, 2007 - 07:56 PM
All rear susp. bearings use these type bearings.I just serviced mine today and they all appeared to have the yellow" plastic" surrounding the needles. i had never heard of removing these so I just applied the moly grease on them after wiping them off. There are sleeves and collars that must go back together a certain way so work carefully and use a manual if you have one.
  • drtbk4ever
Posted March 13, 2007 - 07:30 AM
Yeah, I was looking in the manual and have to admit I am more than a little intimidated by all those pieces. I am thinking I'll use a digital camera to detail the disassembly, so that I will have half a chance of putting them back in correctly.
Thanks for you input.
  • WR_Dave
Posted March 13, 2007 - 07:48 AM
I just did my new '07 and just lubed the bearings with some good synthetic waterproof grease. Easy to do and well worth the effort. The swingarm pivots had very little grease in them from the factory as well as the steering head bearings, but that wasn't unexpected. Just get in there , take it apart , grease all the bearings and learn how it all fits together. That's part of the fun of owning dirtbikes, for me anyway. :applause: Good Luck---WR Dave
  • drtbk4ever
Posted March 13, 2007 - 09:52 AM
Dave, thanks for your encouragement. If I run into problems, I'll give you a call. :lol:
Now you say "good synthetic waterproof grease". Do you mind me asking what you used and where u got it? I think I saw a tub of Bel Ray stuff at a nearby Yami dealer, but I don't know if it was waterproof. Or should I just go to Crappy tire?
Thanks.
  • Dano426
Posted March 13, 2007 - 10:21 AM
Hello Gang,
No cheese in the swing arm bearings. A good cleaning with brake cleaner will do the trick. You can leave the bearings in the swing arm, but if your bikes is over two years old it is best to pull the seals on each end and replace. There are roller bearings between the washers (behind the seals) that need cleaning and grease.
If you are going to grease your linkage every other year I have found it best to pull the "string cheese" and replace it with a good water proof grease (I like bel-rays). You are able to get twice as much grease in there with out the cheese.
Get a good torque wrench and an oem manual and you should be able to do the job just fine.
  • drtbk4ever
Posted March 13, 2007 - 11:22 AM
Hey Dano,
Thanks for the heads up on the seals. I think I'll order (and hopefully pick them up) before I dive into the swingarm.
If I am looking at the parts diagram correctly, it appears I need two oil seals for the outside of the swingarm and two for the inside. Does that sound right?
  • WR_Dave
Posted March 13, 2007 - 03:22 PM
I am using Mobil 1 synthetic grease that I snagged from the shop where I was working. It is used on the highway trucks we were working on. The Bel Ray works well too. You can pull the plastic "cheese" out of the bearings with a pick , just make sure you don't lose any needles. I usually regrease my linkage every month or two depending on how much wet riding we do. I installed grease zerks in the swingarm and the horseshoe link so I can top them up any time I want. I'll help you out if you have any trouble, it's pretty easy. WR Dave.:applause:
  • jams229
Posted March 13, 2007 - 05:45 PM
Every month or two?!?! Holy cow! YOU are hard core. :applause:
I just wish you lived closer to me! I hate doing that job, and I only do it
once a year! by the way, I pay real well...
Jim
  • WR_Dave
Posted March 13, 2007 - 06:01 PM
Jim
Air fare plus labor?????:eek: :lol: Not as much hard core as don't like to let my equipment suffer, also I'm a mechanics instructor and it doesn't look good if my stuff is crap. WR Dave
  • Dano426
Posted March 14, 2007 - 05:49 AM
Hey Dano,
You are correct.
  • BigIan
Posted March 14, 2007 - 10:10 AM
I have seen many threads regarding regular service of the rear linkage (grease re-pack), does the swingarm need as much maintenance as well?
  • Dano426
Posted March 14, 2007 - 10:45 AM
You guessed it. The linkage seems to need a bit more cleaning, but it all gets drug throught water and mud at the same time.
  • drtbk4ever
Posted March 14, 2007 - 04:59 PM
Thanks for all your help guys.
I got my Bel Ray Waterproof grease today and a portable heater for the garage (since it's still barely above freezing here). One local dealer didn't have any seals in stock so they wanted to sell me a bearing kit instead. I'll hold off on that and check another dealer for seals.
I'll let you know how it goes.
Cheers.
  • Dano426
Posted March 14, 2007 - 05:56 PM
Cheers.
You will need to order the seals seperately unless you plan on purchasing the whole kit. Wait until you tear in to it. You may need other parts as well. I would take a look at the TT store. Best prices on oem parts
  • drtbk4ever
Posted March 17, 2007 - 08:55 AM
Hey Guys,
Thanks for all your help.
I got this accomplished yesterday, in just under 5 hours. OK, the 1st hour was spent driving around town looking for a socket to fit the swingarm nut. But it went reasonably well and I think I put it all back together properly.
Cheers.
  • Dano426
Posted March 19, 2007 - 06:05 AM
Hey Guys,
Cheers.
By the time I take two trips in the house for more beer it takes me about five to six hours. So you are right on schedule:cheers:
  • drtbk4ever
Posted March 19, 2007 - 07:33 AM
Oops, spoke too soon. Moved the bike off the stand and found a washer sitting there. Must be either the kickstand or the chain roller.
By the way, here is a photo of the string cheese I pulled out.
  • cournek
Posted December 26, 2007 - 10:38 AM
I keep my beer in the garage with me, saves tons of time :banghead:
