Ohlins rear shock
17 replies to this topic
  • dirtbikersa
Posted March 12, 2007 - 10:39 AM
I am looking for a service manual for a Ohlins rear shock. I can get the owners manual off there website but I need to service the shock..
  • KTM-Lew
Posted March 12, 2007 - 11:34 AM
Good luck...you'd have a better chance of having your blind-folded drunk monkey hack into the Pentagon on the first crack, than finding ANY Ohlins shock rebuilding info.
Not gonnna happen!:lol: :applause:
  • blitz11
Posted March 13, 2007 - 06:03 AM
Can I ask why? I just picked up a gasgas with the ohlins shock, and would like some information on changing fluid and maintenance. It seems you can find this for every other manufacturer.
Thanks in advance.
  • KTM-Lew
Posted March 13, 2007 - 06:10 AM
Ohlins hold their cards very close to their chest...they want you to send the shock to them.
  • blitz11
Posted March 13, 2007 - 07:48 AM
If I've done KYB and Showa, is the Ohlins a big jump? I am not as interested in valving as I am routine maintenance. I am just after clean oil and a fresh N2 charge.
Thanks again. I appreciate all of your insight. I've learned a great deal from you.
  • KTM-Lew
Posted March 13, 2007 - 10:21 AM
The only problem would be the reservior piston height. I think the general rule of thumb is 80% of reservior length?
  • thillsam
Posted March 13, 2007 - 10:32 AM
This is what I set any shock with a floating piston to. My Sherco has a Paoili shock that is very very similar in construction layout to an Ohlins.
Ohlins are very very simple to work on, IME, and easy to bleed too. I overhauled/revalved the shock on my girlfreind's GasGas EC200 myself, with no manual and only old Ohlins twin shock experience.
The only specialy tool I needed were a shock needle to recharge.
  • blitz11
Posted March 13, 2007 - 11:50 AM
Thanks again. I have an excellent mental picture here now. This helps a great deal.
  • henrics
Posted March 13, 2007 - 03:32 PM
push the reservior piston all the way in then back out 8mm, then you have the right amount of oil
  • dirtbikersa
Posted March 14, 2007 - 12:47 PM
I woud like to do a full strip down and reassemble but I guess I will stick to oil change and recharge with nitrogen. Why not measure the amount of oil that comes out and then refill with same amount, maybe little extra?
  • mog
Posted March 14, 2007 - 01:55 PM
thats not accurate enough, get it wrong and you have serious problems.
  • henrics
Posted March 14, 2007 - 04:48 PM
It`s very hard to put a measured amount back in the shock . you got to bleed the air out and its usually messy, how much of the oil got to your workbench?
  • dirtbikersa
Posted March 15, 2007 - 12:09 PM
I still think it will be more accurate than guessing 80% of the resevoir length?? Somewhere this info must be available??
  • KTM-Lew
Posted March 15, 2007 - 12:28 PM
Have you ever done a shock with a piston style reservioir? :applause:
  • mog
Posted March 15, 2007 - 02:21 PM
You dont guess 80% you measure it.
  • dirtbikersa
Posted March 16, 2007 - 09:52 AM
The only shock that I have ever serviced is my showa shock..
I will hopefully get around to trying it this weekend.
  • dirtbikersa
Posted March 16, 2007 - 09:53 AM
Aha, that makes more sense. :applause:
  • 44Dwarf
Posted August 12, 2015 - 05:10 PM
I know this is old topic but I found it while looking for the gas filling tool.
Here's a link to a manual.
http://www.motorspor...shop_manual.pdf
Hard part is finding reasonable prices on the service tools as there not the normal filling tools.
