Why...?
4 replies to this topic
  • XRsteve
Posted March 12, 2007 - 08:58 AM
Why does it seem like not very many people use steering dampers on their 650Ls? I just put a scotts on mine last week and it feels so much better at high speeds. I took it out yesterday and it feels like its riding on rails. No wobble or headshake, even at 75+ mph. It was pretty easy to install, no harder than the kit I put on my XR400.
  • Jawmail
Posted March 12, 2007 - 09:00 AM
I'd love to put one on, a lot of $ though. Did you use the under bar mount, did you need new bars, etc..
  • CTXr650L
Posted March 12, 2007 - 09:18 AM
i put one on mine when i had only 100 miles on it, made a huge difference in high speed stability (i do alot of highway)... just converted to usd forks and am able to run alot lower setting on it but i still like the benefits the scotts damper give me :applause: oh yeah, mine was the top mount one, just had to tweak the crossbar a little for clearance but everything else worked just fine
  • goblin127
Posted March 12, 2007 - 09:57 AM
It's the expense of it.
  • XRsteve
Posted March 12, 2007 - 11:30 AM
I used the standard bolt on kit. The bars are renthal cr high. I did have to remove a little material from the steering lock assembly, but it wasn't too hard. The trick was to make sure everything had clearance before you get it all back together.
I also had to trim the dipstick a little. Having a damper and an IMS 4 gallon tank makes it a little harder to get the dipstick threaded in, but still not bad.
