AIS plug off
8 replies to this topic
  • splitpunk
Posted March 11, 2007 - 06:55 PM
Here is a question for all you motor heads. Why not just put a 3/8 ball bearing in the rubber hose between the check valve and the metal tube going to the exhaust instead of tearing off and pluging with the 50$ ais removal kit? Will it work or will it cause some kind of damage to the bike. Just my 2 cents but it would seem to stop air flow and the pop on decel. The ball would be tight and no air would go in or out. 50cents for a 3/8 ball bearing. Let me know please.
  • splitpunk
Posted March 11, 2007 - 09:55 PM
Anybody, please, I would really like to know.
  • JSanfilippo
Posted March 11, 2007 - 11:54 PM
The Honda guys use JB weld disable their pumps so I guess the bearing would work...
  • gregwr450f
Posted March 12, 2007 - 12:22 AM
ball bearing with a cable tie either side to keep it in place.
  • splitpunk
Posted March 12, 2007 - 05:11 AM
Ya I think it should work and help save some cash and time. But what I am wondering is why has nobody came up with this fix.:applause: It seems so easy I wonder if it is too easy. Anybody?
  • msgbean
Posted March 12, 2007 - 08:21 AM
If you make your own parts you can remove it and block it off for free or you can leave it alone which is also free. It does not change the performance of the bike. However, if you open up the rest of the bike by doing the mods the kit also includes stuff that you can't make like a needle and jets which needs to be changed to make it run right.
  • splitpunk
Posted March 12, 2007 - 03:10 PM
Right I did all that with the FMF kit when I bought the pipe. It was popping on decel and I put 2 ball bearings in the hose 3/8 and no more popping on decel:applause: The air does not go in so the air does not go out. The only thing I have not done is cut the grey wire.
  • WR_Dave
Posted March 12, 2007 - 03:21 PM
Most of us remove the AIS to get rid of all the extra crap on the bike. The ball bearing idea would work fine if you just want to disable the AIS. Don't forget the vacuum hose as well. I don't have the '07 kit yet so I just cut the pipe off near the head plate and pinched it shut and welded it. Reinstalled the plate and got rid of all the junk. http://img.photobuck...ve/100_1036.jpg WR Dave
  • Tough Guy
Posted March 12, 2007 - 04:00 PM
I had my dealer install the AIS delete kit and with the jetting/needle changes etc.. I have zero bog and no popping on decel, the best $39.95 I have spent on it yet...Great mod for the money.
Chris
