cracked front rim/wheel
5 replies to this topic
  • bork
Posted March 11, 2007 - 06:57 AM
I had to ride a ways on a flat. Now when I went to change, I noticed a crack from edge to 1/2 way to center(in between spokes)on alum rim. Looks like where factore seam/weld is. Any problem in having this welded up & holding successfully. I dont care about the site of the bead of weld.(I would not grind down for apperarce) Has anyone else done this?
  • cleonard
Posted March 11, 2007 - 08:48 AM
You can try it, but it usually requires a new rim to fix. My friend had the same thing happen, crack at weld, on his KTM and it cracked again shortly after being welded.
  • Wheels up
Posted March 11, 2007 - 09:34 AM
My front wheel cracked a few years ago. I am a welder so I tried it. I havnt re cracked it yet. Everything is still fine. It was a big crack to.
  • XR4DEZ
Posted March 11, 2007 - 10:17 AM
I have one I'm going to try this on, hope I have the same luck. I just want to use it as a spare at the races. I'd hate to get a flat on the first loop and have to stop.
  • bork
Posted March 11, 2007 - 06:03 PM
I know of a super duper good welder who does stuff on fighter jet engine parts. So if anyone can do it, it would be him.
  • Desertskyy
Posted March 12, 2007 - 08:31 AM
I have a small crack in mine at the same spot. I am probably going to replace the rim with an Excel.
  • 22 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 7 replies
  • Hot  28 replies
  • Hot  35 replies
