HELP !!! 01 XR650R won't start
13 replies to this topic
  • PIP RC51
Posted March 10, 2007 - 10:45 AM
In the winter months I try and start the bike wvery 3-4 weeks to run some fuel through it. In the last couple months I did this without much issues. 1/2 dozen kicks and it would fore up, I would run it till hot, idle good never a problem.
UNTIL NOW.
Yesterday it was 50's here in Pittsburgh and I thought I would run it round the block a few times. I kicked till my leg went knumb, tried to bump start it. I got it running once or twice and it would idle then shut off in 30 seconds. I took the plug out to dry it cuz at this point fuel was dripping out of the carb. I thought the floats were stuck and tapped them a few times. Today.................. the same. NO GO. :applause:
And to make matters worse, while kicking it on the kickstand with my fat a$$ the kickstand broke.
1st- Does anyone have an extra kickstand?
2nd- Any ideas what to do now?
I thought I was out of fuel but there is enough in it to flood the carb and start dripping out.
I am ready to burn the thing......... HELP !!!
PIP
  • hypersthenos
Posted March 10, 2007 - 11:08 AM
Did you try starting it (after letting it sit overnight to dry out) with the choke on the partial open setting? Had the same scenario happen up here as the weather warmed up to the 50s & started right up. If it's flooded did you use the fooding procedure? (turn off the gas, pull the compression release in kick it through 10-15 times), then hold throttle wide open with choke off & try it.
  • creeky
Posted March 10, 2007 - 11:31 AM
Install a new spark plug.
  • HawkGT
Posted March 10, 2007 - 04:30 PM
Drain old fuel and clean carb.
  • prockish17
Posted March 10, 2007 - 09:07 PM
I second the spark plug, this has happened to me twice now. Put in a new plug. I would even go as to say it is black also.
  • ballisticexchris
Posted March 10, 2007 - 10:12 PM
Change your pilot jet (use a 70 or 72). It will start right up.
  • ttmojo1
Posted March 11, 2007 - 04:01 AM
You kicked on it w/the kickstand down?:applause:
Not tryin to be a jerk but,thats how a girl starts a bike.
Maybe you should sell the brp and get a ttr225 w/e-start.
Tony
  • PIP RC51
Posted March 11, 2007 - 08:02 AM
Well thanks for the replies, NO I didn't put a new plug in yet. The one that is in only had 1 day of riding on it but I did take it out a few times for it to dry and to clean it up. (haven't been to bike shop yet) It looks good other than being wet all the time. And I know not to kick it on the kickstand but I was so ****straded from all the kicking that I just wanted a break, and that was what happened...... "I got a break" :applause:
I just wanted the easy way out before I rip into the carb but that looks like what is going to happpen today.:lol:
PIP
  • prockish17
Posted March 11, 2007 - 11:13 AM
Get rid of the stock carb, then you won't have to wonder why it doesn't start. Then it is either the plug or no gas.
  • PIP RC51
Posted March 12, 2007 - 02:25 AM
Thar she blows. It runs, it runs. yesterday I played around with it for an hour or so then finally..............FIRE. :lol: Not sure what I did to get er fired. drained float bowl a few times, switched plugs half dozen times, swore at it a few more times then chugg chugg. FIRE. :applause:
Ran it around the block like a scared rabbit at a dog show. Pissed all the neighbors off really good. :lol:
PIP
  • porterdog
Posted March 12, 2007 - 05:25 AM
Not tryin to be a jerk but...
...but you are. Nice job, noob.
  • PIP RC51
Posted March 12, 2007 - 07:35 AM
:applause: You read my mind.
PIP
  • ttmojo1
Posted March 12, 2007 - 02:29 PM
"Noob".....thats a good one!:applause:
Tony
  • pgiinc
Posted March 12, 2007 - 05:41 PM
BRP crap to start
compression relesse in
kick it thur 5 times
compression relesse out
find tdc
compression release in to just rollover top of tdc
2 big throttle twists
kick her ass solid
this alpplies to my elderbrock carb . no choke
these bikes suck to start
did you see Dust to glory when he couldn't start his bike in the pit and got passed ggrrrrrrrrrrrrrr
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  158 replies
  • 17 replies
  • Hot  60 replies
