stator resistance question..
1 reply to this topic
  • mattymurn
Posted March 10, 2007 - 02:09 AM
Ok,
bike is a XR650R
I rewound my stator based on some of the excellent instructions on this site.
unwound the original 4 poles for the lights and left the 2 poles of the ignition alone. I wound 10 poles with 33 turns per pole using 18 gauge magnet wire.
Quite straight forward. I measured the resistance of the new windings and measured 0.6 ohms. Basically right on the money for what others have done.
While I was at it I measured the resistance across the ignition windings which I DID NOT touch. The resistance is around 80-90 ohms ?? My question is, is this normal. Doesnt' make sense to me should it not be around the same resistance or less, given only 2 poles wound ?? I was very careful with the original ignition windings so I don't think anything was compromised. Does anyone have a spare stator that they can measure to verifiy. The manual is not very clear what this value should be ??
thanks for any help
Matt
  • suharianu
Posted March 10, 2007 - 07:29 AM
its OK.ignition coil are made of thinner wire and many more windings to get 200v where lighting is 12v
