Drilling holes in piston?
60 replies to this topic
  • nac-nacer
Posted March 09, 2007 - 02:13 PM
I just got a new wiseco piston kit and i'm getting ready to do a top-end. The last time i did a top-end on the bike i didn't drill the holes for the exhuast bridge but on Dirtrider.net i just read about a guy who didnt and it destroyed his plating and did horrible damage to the piston.I've got the cylinder off and it looks perfect plating wise, should i still drill the holes.
Thanks
___________________
91 cr250
04 crf100
  • CharlieT
Posted March 09, 2007 - 02:19 PM
It won't hurt anything if you do and it might if you don't.
  • redrocket190
Posted March 09, 2007 - 05:43 PM
If you have a bridged exhaust port, and that bridge has not been relieved, you should drill the holes. They will allow un-burnt pre-mix from the crankcase to cool the exhaust port bridge and prevent it from expanding and possibly pinching the piston. If the holes are not needed, being there will not do any harm.
  • cr2fidy
Posted March 09, 2007 - 08:09 PM
call me un-educated but i'e never heard of drilling holes in a piston prior to installation, is this for wiseco pistons only? i've done several 250 topends and always use oem parts and have never done this
  • KX02
Posted March 09, 2007 - 10:55 PM
Yes, it's for Wiseco. I also always use stock or better yet, Vertex pistons.
  • Slodad
Posted March 11, 2007 - 09:09 PM
Just did the same for my son's 2002 CR250. Starts right up, but he says that it now acts like it's very rich. I haven't ridden it since the rebuild, so I can't vouch for his diagnosis. It was jetted just about perfectly before the rebuild, but it also had about .006" of piston clearance and the ring endgap was over .035". Perhaps increasing the compression caused it to run richer.
  • Wiseone
Posted March 12, 2007 - 05:18 PM
This is only to cool and lubricate the bridge. Not all 250's have this.
It is good practice on any mfg's piston.
Back in the day of iron bores even with the bridge relieved no holes meant the bridge expanded with heat and pushed into the piston notching the ring and shortening the whole package life.
The reason they are not predrilled is some oe cylinders have the bridge out of spec to port or starboard and the predrilled holes miss the bridge and spew the charge out the port.
Hmmm Vertex a Wiseco step sister now.
  • HawkGT
Posted March 12, 2007 - 05:25 PM
What does it mean to "relieve" an exhaust bridge?
  • Rob129
Posted March 13, 2007 - 06:35 AM
This is the jug out of my CR500. See how the bridge is relieved?
Basically, you take about a couple of thousandths off the bridge.
You only drill Wiseco's! Wiseco's are forged and expand funky versus cast pistons. Cast pistons do not need to be drilled.
  • 317
Posted March 13, 2007 - 09:58 AM
Just do it.
  • jjgixxer
Posted March 13, 2007 - 10:41 AM
I would, I do our wiseco's in our 02 cr 250. :applause: our exhaust bridge has been relived also.
  • coolbikeguy
Posted March 13, 2007 - 10:45 AM
i second the vertex
  • Wiseone
Posted March 13, 2007 - 01:58 PM
Very nice illustartion!
The Bridge is expanding into the piston not the reverse
Again This is good practice with any piston cast or forged.
The Thermal expansion issues of Forging's went away many years ago with new alloys. Heat treat and forging design. The Old tales are hard to die. Forgings can now be set up as tight or tighter piston to cylinder clearance than casting,s.
My own 03 KX 250 is using the single ring Seizco at .0018 the OE casting is set up at .0023-.003
RC,s RM250 in 05 used a similiar single ring forged Seizco to win both sx and mx championships. I did not notice Goose warming it up any different than anything else
  • kx_rider53
Posted March 13, 2007 - 02:28 PM
Is this just for honda's?
  • Wiseone
Posted March 13, 2007 - 03:31 PM
Nope. Anything with a exhaust bridge especially a Iron Bore.
  • kx_rider53
Posted March 13, 2007 - 04:37 PM
So for my kx 125, would i need to do this? I have used it without the holes, no damage has seemed to occur yet.
  • Rob129
Posted March 13, 2007 - 05:37 PM
Thats what he thought too!
Actually he has a base gasket leak also. But you can see the scoring on the intake skirt due to lack of lubrication holes. Easy way to tell...pull your pipe off, shine a light up in there and have a look-see.
  • kx_rider53
Posted March 13, 2007 - 05:58 PM
I looked at it when i did the top-end this winter. There was a little blow by on the exhaust side (maybe 1/4 in.) with about 30 hours on it.
  • Rob129
Posted March 13, 2007 - 06:05 PM
Keep an eye on your compression. You did a top end.....re-ring?
  • Wiseone
Posted March 13, 2007 - 06:37 PM
Actually we are looking at the exhaust side of the piston pictured.
The Exhaust side is the Hot side that includes that exh.bridge on some models.
Was this a test to so who was paying attention?
The failure shown is all the work of the extreme lean condition of the base gasket leak. Exh. bridge damage will be more limited to where the bridge contacts the piston vertically. Tight ring end gaps can/will also have more tension on that area causing accellerated wear. And those cooling/lube holes only cool/lube the bridge not slobering it all over the exh.side of the piston.
cr125 build questions by austin_honda
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • 7 replies
Honda Cr85 problem by Bashkillem69
  • Hot  30 replies
My new near-mint 2002 cr250r by md30
  • Hot  51 replies
CR125 High Revving on Start Up by Will I Am
  • Hot  28 replies
New to the forum. Question regarding cylinder scoring and break in by BlakeCR
  • Hot  50 replies
