some sprocket advice
6 replies to this topic
  • Express
Posted March 08, 2007 - 07:13 PM
Ive got a 06 WR450 that is plated. I dont ride the road very much, just to get to the trail. Sometimes Ill do 20-30 miles of road to get to a ride. My WR is a great bike but Ill never confuse it with a street bike. It feels like Im running the crap out of it on the highway at about 65mph.
Living in the northeast I do alot of tight trail and rocky riding, so alot of slower trail work. Id really like to have a little lower gearing but that bit of road time has prvented me from changing out my sprockets.
For those that have changed out the stock tooth sizes how much of a difference did you really get? Perfect world I wish the WR had a 6 speed tranny but thats not gonna happen. I need a lower 1st, 2nd and a bit of 3rd but want my 4th and 5th to stay where theyre at. I know thats not happening.
Any suggestion on a front/rear combo that would offer a good balance for what Im describing?
  • Fullbore4
Posted March 08, 2007 - 09:54 PM
I run 13/50 without any trouble on my 06....gives me a little more torque, wears about the same as stock (14/50) and allows me to cruise on highway at 60-65. Granted its not a highway bike by any means but I don't use it for highway much....my 1 cent.
  • Island Boy
Posted March 09, 2007 - 07:00 AM
I am probably 70% street and 30% trail on enduro tires with my 07. The bike is totally uncorked and has amazing torque. Almost too much in the lower gears for what I use the bike for. Next week I will be dropping 2 teeth on my rear sprocket to 48 to extend the gears a little and gain some top-end. (I dont expect much of a difference, but I want to experiment anyway). I could have gone lower by 3 or 4 teeth or gone up a tooth on the front but I didn't want to risk losing too much torque. I will report back on any difference, pro's and con's etc. when I am done.
  • muddyken
Posted March 09, 2007 - 01:43 PM
Any suggestion on a front/rear combo that would offer a good balance for what Im describing?[/QUOTE]
you have already got a good balance with the standard sprocket sizes. dont go to making big changes as you will end up way out, i would suggest maybe go up one tooth on the rear and try that.... it worked for me......... you will notice the biggest change if you go up or down a tooth on the front but i think i remember right that one tooth up or down on the front is equal to three on the rear, but i think this is to much change the improvement you are looking for. good luck:ride:
  • Express
Posted March 10, 2007 - 09:10 PM
Thanks for the info. I didnt want to start a sprocket collection trying different combos.
Muddyken did you change out your rear sprocket? If you did what kind of top end drop did you see?
  • SID013
Posted March 11, 2007 - 02:30 PM
Hiya, I always play around with this gearing calculator to see what effects sprocket changes will make to my speeds in various gears.
http://www.4strokes....earing_calc.xls
Hope it helps.
Cheers from Oz
Peter
  • dobbo
Posted March 11, 2007 - 06:37 PM
Changed my 06 from 14/50 to 15/50 and much better for top end HWY and still has heaps of grunt for low end. Cheap and same length chain.
Hope this helps.
Richie
