07 gearing
3 replies to this topic
  • sjwr450
Posted March 07, 2007 - 07:57 PM
The 07 has a 13 tooth front stock and my 05 has a 14 tooth. It appears in the manual (I'm not expert on the gear ratios), that the overall gearing is about the same. On my 05 I run a 15/50, for Baja. I need about the same gearing. Stock 07 is 13/50. Should I simply bolt on a 14? I'm a little bummed because the 15 is easier on the chain.
Thanks
  • SXP
Posted March 07, 2007 - 10:45 PM
Thanks
The primary reduction ratio on the 07 is different from all the other model year WRs (hence the 13T front sprocket). The 1-5 gear ratios are all the same between all years.
  • sjwr450
Posted March 08, 2007 - 06:28 AM
so 14?
  • SXP
Posted March 08, 2007 - 06:55 AM
Sorry, I really wasn't much help, was I?
Yes, the 14T should put you in same ball park as the 15/50 combo on previous year bikes.
