how can i tell what year my bike is??
20 replies to this topic
  • wannarace777
Posted March 07, 2007 - 02:34 PM
Hi all bit of a silly question here just bought a yzf250 and was told it is a 03 model but how can i tell what year it is?
Cheers Dave
  • Taylors
Posted March 07, 2007 - 02:36 PM
Ck the 10th digit in the vin, it should be a 3 for a 2003 model
  • wannarace777
Posted March 07, 2007 - 02:41 PM
thanks for your help, mine starts with CG can i work it out from that?
Cheers Dave
  • greyhd
Posted March 07, 2007 - 06:21 PM
03s had 46mm forks, 04/5 have 48mms.
  • av
Posted March 07, 2007 - 06:44 PM
Cheers Dave
List your VIN number, mine is in the picture below, notice that the 10th character counting from left to right is the year -> i.e. 6 for 2006, that character is right before the production unit number, i.e. A005294, mine was the 5294th bike that came of the assembly line destined for the USA.
Since you're in England, your VIN may look differently, post it and maybe we can figure it out - or call your dealer and ask them how to get the year from reading the VIN, hopefully they will know.
http://av-motorcycle...ls/IMGP3495.JPG
  • MX813
Posted March 07, 2007 - 07:58 PM
Very cool. Now I know I have the 620th 04 yz250F...ah...now if it would run.
  • GYTRthumper623
Posted March 07, 2007 - 08:05 PM
you could call up a yamaha rep with your VIN # and he or she will tell you the year
  • Justin89
Posted March 08, 2007 - 08:24 AM
For future, you could tell that the 2001-2002 yzf's have different shrouds and side panels than the 2003-2005. Also, it should have the make and model on the top of the frame by the dip stick. :applause:
  • wannarace777
Posted March 08, 2007 - 12:00 PM
my vin is XCG10C016758X
would be great help if you could work that one out
  • 250Thumpher
Posted March 08, 2007 - 01:28 PM
Is that the vin on the motor or on the frame?
Regardless where it was made, the jin should start with JYACG
Look on the steering tube on the right hand side. If it does not start with JYAC, just do everyone a favor and call a rep, or even call the dealership.
  • wannarace777
Posted March 08, 2007 - 02:12 PM
yes that is the vin , will try a dealer tomorrow
  • av
Posted March 08, 2007 - 02:14 PM
The identifier on my case doesn't look like that either... Not sure how to read your VIN wannarace777 - sorry, check with your dealer... :applause:
http://av-motorcycle...or/IMGP3791.JPG
  • 250Thumpher
Posted March 08, 2007 - 02:16 PM
CG10C016758 is an 11 digit code, whereas the engine vin is 11 digits as well...
  • 250Thumpher
Posted March 08, 2007 - 02:43 PM
Actually, here's a way to find out:
Look on the carb on the left hand side. You will see numbers and letters engraved into the carb. What is this number?
Look at the kickstarter and you should see 3 letters/numbers on the shaft (most likely starting with a 5) What is this code?
-Phill
  • ktm868
Posted March 08, 2007 - 05:01 PM
yo honda dude what r u doin get out of here
  • ItzBACON
Posted March 08, 2007 - 05:46 PM
a VIN will be 17 digits long. If you don't have 17 digits in your number, it's not the VIN
  • SherpaHead
Posted March 08, 2007 - 08:58 PM
The VIN will be the number on the frame. You want to check the 10th digit
there as stated previously. That will give the year for most any bike except a
real antique. We have a chart that shows the years for what the 10th digit
is down at the bike shop. That info must be available somewhere on the web
as well.
  • Justin89
Posted March 08, 2007 - 09:40 PM
Or else what...I have a yzf too bro.
  • wannarace777
Posted March 18, 2007 - 10:43 AM
here is my carb number 5sg2-10qa16
and kick start is 5NL
  • RallyImprezive
Posted March 18, 2007 - 12:08 PM
that was pretty lame.
