Tail ilght dimming when engine is reved
4 replies to this topic
  • Paul2005
Posted March 06, 2007 - 06:20 PM
Hi All,
Have a problem with the back tail light dimming when the engine is reved, i think it might be the regulator but the front lights are not dimming! does anyone know if the front lights go through the regulator as well? if they don't i wouold guess it the regulator / rectifier thats gone. Whats everyone think
Many thanks
Paul
  • cleonard
Posted March 06, 2007 - 06:30 PM
It could be a poor connection. Revs make vibrations and that might be making a poor connection worse.
  • porterdog
Posted March 06, 2007 - 08:55 PM
Hard to say with no information about your bike...
  • Paul2005
Posted March 07, 2007 - 08:18 PM
sorry porterdog its an 97 xr600
good point cleonard i did have problems before with the connection but i thought i done a good job repairing it, must go over the connections again
  • bigredxr
Posted March 08, 2007 - 03:31 AM
Put a dvom on the battery and see if the voltage drops when u whack the throttle. Your looking for a signicant drop also 9.6 to 10 volts. If it does the ignition system is pulling the voltage to fire the ignition and this would indicate a weak charging circuit. Also check your battery static voltage 12.2-12.4volts. 13.4 to 14.2 approx when running. Our take 2 sec. and have it tested. Also like u said check all connections at pwrs and grds. good luck:thumbsup:
