Electrical failure
1 reply to this topic
  • tvrjohn
Posted March 06, 2007 - 04:12 PM
Starter clutch retaining screws have sheared off, and damaged the stator windings.
When this happens, does it fry the reg/rectifier or spark plug cap coil unit ?
As cannot get a spark at the plug, after replacing stator !
  • new2blu
Posted March 06, 2007 - 06:45 PM
First you may want to try a new plug I have seen carbon short the insulator before. If that no fix then---Possibly an incorrectly wound stator??? Look in your manual on and take an electrical reading(resistance) of the stator--yamaha calls the stator an "AC magneto". Also check the pick-up coil resistance and the ignition coil resistance. Let us know what the fix is.
