Quick Auto Decompresser Question
41 replies to this topic
  • TheRainMan
Posted March 09, 2007 - 02:58 PM
#21
Rainman:
Wicked. If you don't mind me asking, how much did you pay for the cam? And did you install it yourself? If so, any difficulties?
The CAM was around $175 and another $20 for the shims.....I had a dealer do it since I wasn't in the mood to do it myself. I'm a retired aircraft mechanic (now i'm a cop) and sometimes it's nice to let someone else to the work!
  • creeker
Posted March 19, 2007 - 11:51 AM
#22
If you don't mind... how much did the dealer charge to install?
  • tc66nova
Posted March 19, 2007 - 01:02 PM
#23
Using a 450 cam in conjunction with the other 426 sprockets will mean wearing out your cam sprockets and/or chain.
B.S. I have hundreds of hours on mine with NO detectable wear and several others on this board have more hours, miles, and races than you can count with out any problems.
  • creeker
Posted March 22, 2007 - 03:16 PM
#24
When doing this mod, would you go ahead and replace the cam chain as well? If so, I assume you would go with the stock 426 chain, correct?
Posted March 22, 2007 - 03:26 PM
#25
First, yes, if the chain has not been replaced in over a year or so, replace it.
Second, there is no option to use anything other than the 426 chain, since the 450 chain is significantly shorter (something like 15+mm). Besides, the pitch difference, which doesn't amount to much running over a quarter of the fairly large cam gears, would be a problem for the smaller, faster turning crank gear.
  • axman2292
Posted March 26, 2007 - 04:14 PM
#26
did you install the cam yourself or have the shop do it
  • Butta
Posted March 26, 2007 - 06:58 PM
#27
This is an easy mod to install. Save yourself the $ and buy from the TT store. The only thing you'll need your dealer for is the exchange of the shims, once you find out what size you need (IF they exchange them for you, otherwise you'll be having to buy them).
Honestly, you're looking at a 2 hour job max if you take your time. Follow the links Grey has for the cam mod and you'll be set.....piece of cake. (and you can pocket the extra dough!)
  • TheRainMan
Posted April 12, 2007 - 01:59 PM
#28
It was around $150 to have the dealer do it, it's not a hard MOD I just didn't feel like doing myself...
  • creeker
Posted April 13, 2007 - 02:54 AM
#29
I guess I will try and do it myself... is the chain hard to change out? I heard it was really easy in some of the threads and then I read an article in Dirtrider, I believe it was, and it sound like you had to have an ignition puller and everything just to change the cam chain.
Posted April 13, 2007 - 07:46 AM
#30
You do need a flywheel puller, but they're cheap, and readily available.
http://www.thumperta...994#post3024994
  • jrny426
Posted April 13, 2007 - 11:34 AM
#31
TT and many other suppliers will ship to Canada. Be sur to have anything you purchased shipped via USPS and not a courier service, you will avoid heafty brokerage fees this way. There are no tarriffs or duties on new or used motorcycle parts. You will probably have to pay taxes and a small handling fee when it comes through customs.
So it's a lot cheaper in the long run?After exchange and the other fees?
  • Dustin_Mabro
Posted April 13, 2007 - 11:52 AM
#32
I did it a couple months ago, a couple hours and the money to buy the part...nothing hard at all.
  • robg
Posted April 13, 2007 - 09:51 PM
#33
I just did it and it is cool. should have done it sooner. Bought it when I was down in the states for 104.00 bucks from TT store. shipped to my hotel in 2 days. It's night and day difference. The only thing is I had to reshim from 175's to 195's no big deal. The lobes are a bit smaller. There is a really great post on TT that has lots of detail on what to do.
Good luck
  • robg
Posted April 13, 2007 - 09:59 PM
#34
Don't forget you gotta plug the hole where the decompressor hoochie used to be. TT sels the billet plug, Yamaha sells and plastic one.
  • Dustin_Mabro
Posted April 16, 2007 - 04:21 AM
#35
well...you don't have too....
Posted April 16, 2007 - 08:30 AM
#36
And you can get a brass one at most auto parts stores for about $0.75 (18mm cup/freeze plug).
  • 426Braap
Posted April 16, 2007 - 09:40 AM
#37
I just bought a used 426 with the decom 450 cam already installed, but when the dealer installed it they left the decompression lever still attached. Can/Should I remove it and plug the hole or is it ok to stay there for future use?
  • Dustin_Mabro
Posted April 16, 2007 - 09:49 AM
#38
from what grey told me...and i'm sure he'll correct me if i miss quote:busted: but he said that you can leave it in iffin you want but it could get in the way when you shim. I decided to leave mine in for a flooded event...but yesterday was looking into taking it out as the bike is running tip top lately.
Posted April 16, 2007 - 10:01 AM
#39
As long as the return spring stays on the lever, the lever can stay in the bore, but yeah, it will be in the way of any valve adjustment you might have to do on the right exhaust.
  • 426Braap
Posted April 16, 2007 - 10:27 AM
#40
Is there a link here somewhere for easy removal of the lever?
  • 9 replies
  • 5 replies
  • 0 replies
  • Hot  47 replies
